It is currently Sun May 10, 2026 12:32 pm
 Post subject: Rear Leafs
PostPosted: Sat Dec 24, 2005 1:53 pm
Earlier this month I picked up a pretty disheveled 62 Lancer Coupe with a 62 Valiant front clip to strip of parts for my 62 Valiant. Today I was out working on it and when I examined the rear springs and compared them to those in the Valiant; I found that the Lancer has 5 leaves while the Valiant only has 4. What do I have? Is it a heavy duty rear spring set perhaps? I'm just wondering if it would be worthwhile taking them apart to clean them and put new pads in them.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Dec 25, 2005 11:07 pm
4-leaf: Standard
5-leaf: HD and wagon
6-leaf: XHD (HD Wagon)
All varieties are readily available new, e.g. from Espo.
PostPosted: Mon Dec 26, 2005 4:00 am
Dan -
Do you know if the 6 leaf XHD option extend into the late 60's (1968 Dart) as well?
-Mac
PostPosted: Mon Dec 26, 2005 8:23 am
The more I think about it (look at the timestamp on my initial response...) the more I remember that the "6-leaf" option was actually an XHD 5-leaf stack with a little stub leaf at the bottom.
And yeah, HD options were available in the late '60s. Remember that all A-body rear spring assemblies are interchangeable, though some mount plate modification is required to put '64-up springs in a '60-'63 car.
PostPosted: Mon Dec 26, 2005 11:40 am
I originally posted that they were 6 and 5 leaves respectively but I was smoking something I think because the Lancer has 5 and the Valiant 4. I've also looked at the cost of the interleaf liners and bushings and have concluded that I can get brand new springs for little or nothing more than the cost of rebulding the old ones. I might take them apart and clean them to get by for a while but I will probably replace them in the long run.
What would be really sweet is if the T-bars are also heavy duty. The ones in the Valiant are badly rust pitted, a sure recipe for a broken bar, so they must be replaced. The bars in the Lancer are in excellent condition but I don't have them out yet to see what they are. Maybe next weekend I can make some progress.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Dec 26, 2005 3:34 pm
T-bars, also, swap clear across all years and models of A-body.
As far as AZ vs. OR -- they're my two favourite states!
PostPosted: Tue Dec 27, 2005 9:41 pm
Talking about leafs, my father long time ago added a extra leaf to my actual ´71 Duster, since now I´m making my car ride lower, front is now one inch lower, but now the tricky part is in the back.
Can I just remove the extra leaf and that will lower my car a bit?, will that remove stability or something? also, extra leafs are located on top or is the lowest leaf?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Tue Dec 27, 2005 10:20 pm
if you want to lower the back get some lowering blocks.
http://store.summitracing.com/default.a ... search.asp
70 Plymouth Valiant 4dr
PostPosted: Tue Dec 27, 2005 11:21 pm
The extra leaf will be shorter and at the bottom.
Leaf spring packs are like an upside down pyramid, with each added leaf getting shorter than the previous (2 leafs may be same length)
An overload leaf would be the shortest, plus overload leafs are usually thicker.
PostPosted: Wed Dec 28, 2005 3:14 am
Lowering blocks would be better. If you take a leaf out you make the spring softer as well as lower and with reduced suspension travel you don't want it softer or you'll be hitting bottom on every bump. There are disadvantages to blocks, but if you only go 1 inch it should work fine.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Dec 28, 2005 3:47 am
I'm pretty sure it's also possible to lower an A-body a little by flipping the spring hanger at the front of the leaf upside-down.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Dec 28, 2005 6:21 am
One can also make the rear "adjustable" with a two-position hanger:
http://cgi.ebay.com/ebaymotors/Mopar-NE ... dZViewItem
PostPosted: Wed Dec 28, 2005 9:50 am
Ok, then the leaf closer to asphalt is the extra leaf (also is thick) and if I remove it, technically nothing wrong will happen right? only my car will lower a bit (meaby the inch I want).
Valiant Duster 1971
PostPosted: Thu Dec 29, 2005 11:28 am
Your spring rate will also decrease. Handling and load carrying will be a bit different. The car will sag more when you load it, and probably have a little more understeer at the limit.
