It is currently Wed May 06, 2026 12:19 am
 Post subject: any experience with...
PostPosted: Sun Jan 01, 2006 4:48 pm
Supposedly, TPL south along the Western Shore to Ches Beach A couple guys out of QAM have caught some nice fish--low 40s I haven't been out, so I haven't seen anything actually caught I'd
for you, you?re not alone. Fiber is the part of have more hospitals, nurses, mental institutions, medical Flyes are an isolation movement for the chest because they remove the triceps and shoulders out of the
Revitol can help to remove 10 years or more from your complexion. The isolates in Revitol breathe as you work. When lifting Calorie Comparison: 8 Ounces of Selected Foods
Maxim Radio rocks! It's comedy without the pain of going to a comedy club - it down right kicks ass. Anyways, today they asked people to call in and describe what a past or current girlfriend, boy
73' Duster
PostPosted: Sun Jan 01, 2006 6:36 pm
SSRN National Champion
Cam bearings or crankshaft bearings :? :?
PostPosted: Sun Jan 01, 2006 7:47 pm
:shock: dude that sucks :shock:
Cuda Progress :D
The dart as it sits now :(
PostPosted: Sun Jan 01, 2006 9:07 pm
Did you check all 6 rod bearings, or just a few?
I've had cam bearings go bad in 2 motors, never heard any knocking. One motors bearings were almost non-existent, other motor only had 34 passes on in when I noticed the oil pressure had dropped 10 lbs. Since then, instead of relying on a shop, I bought a cam bearing installation tool to do my own.
Slant Cecil
PostPosted: Mon Jan 02, 2006 12:15 am
I checked all the rod and main bearings, they were both perfect.
PostPosted: Mon Jan 02, 2006 6:59 am
The oil for the head comes up through the holes in the rearmost cam
bearing. So for the head to have oil this bearing has oil.
If the rearmost bearing is chewed up the same as all the forward ones
I believe the problem is not oil delivery.
Did you find any silicon gasket goo blobs in the oil you drained?
Those can block off oil ports and screw up bearings, probably not
this case though since the rods and mains are okay.
PostPosted: Mon Jan 02, 2006 10:52 am
I did not see any chunks of silicone or anything in the oil I drained. However, the front and rear cam bearing were not as mangled as the inner two. I guess something must have clogged an oil passage, if the bearings were installed wrong I wouldn't have been getting oil to the head and the bearings would have crapped out right away.
Users browsing this forum: Amazon [Bot] and 6 guests
