It is currently Sun May 17, 2026 10:31 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: 7.25 Axle Bearings
PostPosted: Fri Jun 08, 2001 10:23 pm
Trying to locate new axle bearings and seals for 1961 Valiant with 7.25 inch ring gear. Have not had any luck in locating these items at local auto parts vendors............Thanks!
byrd@ldd.net
 Post subject: Re: 7.25 Axle Bearings
PostPosted: Sat Jun 09, 2001 8:11 am
: Trying to locate new axle bearings and seals
: for 1961 Valiant with 7.25 inch ring gear.
: Have not had any luck in locating these
: items at local auto parts
: vendors............Thanks!
I checked Autozone's online catalog <A HREF="http://www.autozone.com">www.autozone.com</A> and they list a part number but they don't carry it. Timken # RW206CCR. Maybe a bearing place like Berry Bearing or Bearing Headquarters would have it.
aschumers@aol.com
PostPosted: Sat Jun 09, 2001 11:20 am
: I checked Autozone's online catalog
: <A HREF="http://www.autozone.com">www.autozone.com</A> and they list a part
: number but they don't carry it. Timken #
: RW206CCR. Maybe a bearing place like Berry
: Bearing or Bearing Headquarters would have
: it.
The 7 1/4 used 3 different axle bearing sizes over the years, the 60-62 (some spilled into 63) were real small and are trouble. (hard to find and ware-out fast)
The long term fix is to swap-in a 64-72, 7 1/4 rear end assy. which has larger and available axle bearings. Note that the 73 and later 7 1/4 have the biggest axle bearing BUT it also has the 5 on 4 1/2 "Big Lug" bolt pattern.
Dennis has the "low buck" fix, keep searching for the needed bearing, I do have a few used ones as a "just get it running" last resort. (they make some noise but all the balls are still round!)
I show some additional bearing numbers to help your search:
RW206FFR
RW206CCR
D88506FR (New Departure brand number)
Good Luck, keep searching around, they are out there.
PostPosted: Sat Jun 09, 2001 6:12 pm
Doug,
The 73-76 cars also came with the 5 on 4" bolt pattern on 4-wheel drum brake equiped cars. Both my 75 and 76 Valiants came with 4-wheel drum brakes and 5 on 4" pattern.
Craig
: The long term fix is to swap-in a 64-72, 7 1/4
: rear end assy. which has larger and
: available axle bearings. Note that the 73
: and later 7 1/4 have the biggest axle
: bearing BUT it also has the 5 on 4 1/2
: "Big Lug" bolt pattern.
: DD
cfield@ll.net
PostPosted: Sun Jun 10, 2001 10:57 pm
: The 73-76 cars also came with the 5 on 4"
: bolt pattern on 4-wheel drum brake equiped
: cars. Both my 75 and 76 Valiants came with
: 4-wheel drum brakes and 5 on 4"
: pattern.
: Craig
Yup, Mopar must have had a bunch of the 5 on 4 stuff in the system because they continued to use it on SL6 cars untill 76. (V8 cars got the big lug set-up)
After they dropped the Dart Valiant models, everything was 5 on 4 1/2.
PostPosted: Mon Jun 11, 2001 7:17 am
: Doug,
: pattern.
: Craig
didn't it work this way?:
73-76 disc cars were 5x4.5" and all had 8-1/4"s (which were all 5x4.5")
73-76 cars that were front drum, either 10x2.5"
or 9" were all 5x4" and all had 7-1/4"s
76 model cars built post Federal disc brake mandate (required that all cars be equipped with disc brakes) came with 4x4.5" with BOTH 7-1/4" and 8-1/4" rears. the 7-1/4"s with 5x4.5" used different wheel bearings and retains (thus the axles can't be swapped into earlier housings...)
as a result, no 7-1/4" came with 5x4.5" axles prior to 1976.
is this correct? thats what I've come to understand...
doug@autohobbydigest.com
PostPosted: Mon Jun 11, 2001 9:22 am
: didn't it work this way?: 73-76 disc cars were
: 5x4.5" and all had 8-1/4"s (which
: were all 5x4.5")
: 73-76 cars that were front drum, either
: 10x2.5"
: or 9" were all 5x4" and all had
: 7-1/4"s
: 76 model cars built post Federal disc brake
: mandate (required that all cars be equipped
: with disc brakes) came with 4x4.5" with
: BOTH 7-1/4" and 8-1/4" rears. the
: 7-1/4"s with 5x4.5" used different
: wheel bearings and retains (thus the axles
: can't be swapped into earlier housings...)
: as a result, no 7-1/4" came with
: 5x4.5" axles prior to 1976.
: is this correct? thats what I've come to
: understand...
Sorry folks, but I have a friend with a '74 Dart Swinger, 318 2V, with front discs AND 7.25" rear, with the 4.5" bolt pattern. Go figure...
madsenl@caltech.edu
PostPosted: Mon Jun 11, 2001 5:19 pm
: Sorry folks, but I have a friend with a '74
: Dart Swinger, 318 2V, with front discs AND
: 7.25" rear, with the 4.5" bolt
: pattern. Go figure...
: Lou
Yes I believe you. I also had a 1975 Dart Swinger I parted out some years ago. Factory slant 6 and disc brakes and 7 1/4 rear axle and 5 x 4.5" pattern
cfield@ll.net
PostPosted: Mon Jun 11, 2001 8:58 pm
I have had several 318 cars with 7.25 axles in them. My 73 duster came that way. I also have seen slant 8.25 cars( usually std)
I could be wrong but frt drums got you the small bolt pattern discs got you lrg. It has more to do with brakes than the motor! Pain in the ass to convert a 7.25 to something bigger smaller axle tubes!
Sandy in Nova Scotia
70 duster
70 chrysler 300 2dr htp
72 d-100 swb adventurer
72vh aussie dodge ute
72 vh aussie charger
73 duster 340
79 l'il red express
82 ram prospector
84 regal t-type 3.8 turbo
96 grand caravan es (wife's)
98 ram SS/T
sandy.colter@ns.sympatico.ca
PostPosted: Sat Jun 16, 2001 9:00 am
I just rebuilt the 7.25 in my 69 Dart. Bought kit from Randy's Ring and Pinion <A HREF="http://www.ring-pinion.com">www.ring-pinion.com</A> that included pinion bearings, carrier bearings, pinion seal, crush sleeve and nut. Price for kit was very reasonable. Axle bearings and seals I bought from a local auto parts store.
ldhale@granitecity.com
