It is currently Sun May 10, 2026 4:29 pm
 Post subject: lacking power
PostPosted: Sun Jan 08, 2006 8:04 pm
i have a 1976 dodge 3 speed PU, it has a Slant 6 in it and i seem to have a major power fall off in 3rd gear climbing hills
PostPosted: Sun Jan 08, 2006 9:21 pm
Welcome to the world of "Small engine in large vehicle". Why not down shift to 2nd?
Are the valves adjusted correctly (says the guy who runs them tighter than stock).
Done a tune up lately?
How are the filters (air, fuel).
Is your truck a half ton or 3/4 ton?
We could use a little more detail here.
Oh yeah, welcome aboard! 8)
PostPosted: Sun Jan 08, 2006 9:42 pm
Hello and welcome! What Eric says about small engines in large vehicles is true. I have a 1986 Dodge Ram with a 225. Thats a 5300+ pound vehicle being motivated by a 225 cubic inch engine with 100 horsepower.
Easy fix- do like Eric recommended, shift into second.
Complex and/or expensive fix- starting upgrading carb, cams, ignition, etc...
Is this power loss new? What are the specs of your engine? ONe barrel? Two barrel? Have you done any changes to the engine recently?
PostPosted: Mon Jan 09, 2006 5:45 pm
What kind of gears have you got, and what is your timing set at. Incorrect timing can be a major pain.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Thu Jan 12, 2006 11:17 am
i dont know the gears on the transmission, and the timing was re done, the carb is a 2 barrel Carter. I have power now, i rebuilt the carburator yesterday, there was a flooded float, and a bunch of grime in the carb, i blew it out with compressed air. also the automatic choke was reversed
Users browsing this forum: Amazon [Bot], Bing [Bot], Nearo123 and 3 guests
