It is currently Wed May 06, 2026 2:52 am
PostPosted: Mon Jan 16, 2006 7:53 am
Charrlie called me yesterday about header flanges and I suggested that I post links to "free-ware" jpg and dxf files of a general design. These files can be taken to any jobshop using a water jet or laser cutter and produced.
Crank scrapers and other windage control devices are really our thing and I wanted to make these files available as a small way to support the Mopar community.
Kind regards,
Kevin Johnson
http://www.crank-scrapers.com/SL6_HEADER_FLANGE.jpg
http://www.crank-scrapers.com/SL6_HEADER_FLANGE.dxf
PostPosted: Mon Jan 16, 2006 12:35 pm
Thanks, I needed that :D
PostPosted: Mon Jan 16, 2006 1:07 pm
I will look into getting my local shop (Hamilton's in Raleigh) to make these reasonably.
PostPosted: Mon Jan 16, 2006 1:42 pm
I have a water jet source if anyone is interested. I would need a pattern that you guys want...the one we use would not work.
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Mon Jan 16, 2006 2:34 pm
as a former waterjet programmer\operator, I suggest going with water over laser. the cut will be much cleaner and you wont lose any strength due to the heat cutting (like you would with a laser). you won't have any potential warping either.
bummer is waterjet is hella expensive. the place I worked at wouldn't even take in a job unless it had a $500 minimum cost.
buy in bulk folks!
