It is currently Tue Nov 24, 2026 10:52 pm
 Post subject: Super Six
PostPosted: Fri Jan 20, 2006 10:53 am
Hello,
I am new to this board , I have a 79 Dodge Aspen Slant 6 1bbl carb. I was thinking about upgrading to a Super Six setup or maybe just swaping the engine for a 318. I'm not racing or anything but this car's rating is about 90hp so it's pretty slow.
If anyone can shed some light on things as far as typical cost and preformance increase on either one of those options I would be very grateful.
Thanks
Also, if anyone can recommend some good shops, I am in chicago. I wouldn't mind driving a couple hours.
Thanks again
PostPosted: Fri Jan 20, 2006 11:59 am
http://www.slantsix.org/articles/supersix/article.htm
Hello and welcome!
PostPosted: Sat Jan 21, 2006 3:31 pm
Hello everyone, since someone is talking about supersix, i've got a question about the 2bl. intake manifold.
In which points does it differ from the 1bl. manifold? Is it just the same except it's got a 2bl. intake? What about the plenum size etc... (i just don't know the influences of these characteristics). The runner sizes?
Thanks for your help
Marc
PostPosted: Sat Jan 21, 2006 3:43 pm
Welllll, there are afew differences. THe cast iron factory Super Six intake is exactly the same as the one barrel except for the carb mounting pad (and some later Super Sixes may have the second vacuum tap in the #6 runner for the lean burn computer system). There was also the factopry cast aluminium intake, which has the same issues as the cast iron but it is made of aluminium. Mopar also produced a superior quality M-1 aluminum intakje but the carb was oriented 90 degrees different than the standard two barrel intake, so automatic cars using this manifold have to fabricate their own kickdown linkage (the M-1 slant six intake is very rare, I have only ever seen one for sale and that was on e-bay a few years ago). The M-1 intake did have larger runners than the other cast iron or aluminium intakes offered by Chrysler.
All other aftermarket aluminium fouyr barrel intakes can be made to run a two barrel carb with the use of an adapter plate.
PostPosted: Sat Jan 21, 2006 4:04 pm
So, if i take a 1bl. manifold and just machine a new carb mounting pad, i'd have a supersix intake right?
Thanks for your help reed.
Marc
PostPosted: Sat Jan 21, 2006 4:44 pm
Actually, the Mopar Performance M1 intake has the same carb orientation as the factory piece: Perpendicular. You may be thinking of the Clifford parallel 2bbl intake.
I've got one on my '62 right this minute. They are rare 'cause they were too expensive.
Maybe! I don't remember the measurements I took when I bought the intake some years ago. But, at the time that intake was available, the guy at MP who was writing the catalogue descriptions was given to telling fibs. Things like the "high compression 9:1" pistons for the slant, which were nothing but stock, standard pistons sold by the six-pack under a part number starting with "P".
The MP M1 intake is, however, a nicer-quality casting by far than the 2-piece welded aluminum production intakes.
PostPosted: Sat Jan 21, 2006 5:15 pm
You know, I think you are right. :oops:
Lucky dog!
My info comes from page 290 of the Mopar Performance "Six Cylinder Engines" book:
Externally [the M1Single Plane Intake Manifold] looks very similar to the cast iron version. There was a two-piece, welded together production manifold built in the mid-70s, but this one is a one-piece design and all new. The intake runners are larger and re-shaped for more flow. Therefore, it makes more horsepower than any previous Slant Six 2-Bbl. intake manifold. The horsepower gain over the cast iron 2Bbl. manifold is approxiamately 3% on high performance engines.
Be advised that the same page in the Mopar Performance bookit also talks about how you shouldn't block the heat cross over on the intake manifold of a street driven slant six car. :? So take this info with a grain of salt...
Marc426- If you wait a few days I will be posting a tech article on how to cut and grind and re-weld a stock one barrel intake manifold into a two barrel manifold. I am in the middle of the process right now and will be posting instructions and pictures. Be aware that this in not for the faint of heart and really requires power tools to be done easily and well. You should also bear in mind that the Super Six was actually a package, not just an intake and carb. Super Six cars and trucks had bigger exhaust, different transmission kickdown linkage, different fuel line routing, different air cleaners, different choke pulloffs, different exhaust manifolds (only the well for the choke pulloff spring), etc... Read the above article for all the info.
PostPosted: Sat Jan 21, 2006 5:18 pm
You'd want to machine-off the 1bbl pad and attach a proper 2bbl mounting plate, either perpendicular or parallel, see this thread for instance. Or you could use www.car-part.com to find a factory 2bbl intake and the rest of the parts.
PostPosted: Sun Jan 22, 2006 1:41 am
:D Just what i needed!! I also checked the article you posted but the pictures aren't any good so i'll just wait for yours.
Either perpendicular or parallel... That's a point i'd like to know more about, does it change anything? I was also thinking of machining it to accept a 4bl. manifold (like aftermarket ones) and then mount a 2bl. pad. This way it would stay adaptable.
Aren't there any plenum sizes problems? Do the clifford and offy are the same "plenum size" the stock is?
Buying? What for? :)
Marc
EDIT : oh i forgot! What differences between the pads where the carb has it's round passages (hard to explain for me) in front of it's barrels and the ones where it's all open?
PostPosted: Sun Jan 22, 2006 6:18 am
Mounting the carb parallel allows for better distribution between the cylinders. As far as the four barrel situation goes, there really doesn't appear to be enough space on the manifold to accomplish it without significantly reworking it. If you had to pay someone to weld it, you would quickly have the price of a new unit invested in it.
The round holes on the manifold below the throttle blade supposedly increase the flow velocity, which helps your low end torque a little. One street vehicles, you generally don't run at WOT enough to justify an open base.
PostPosted: Sun Jan 22, 2006 8:33 am
There isn't enough space on a one barrel intake to make an opening for a four barrel unless you cut the manifold top and side off and weld a box on to extend the overall surface area on the top of the intake. Another problem is that there is not enough space between the driver's side carb stud bolt hole and the inboard bolt hole for the exhaust manifold to make a one barrel manifold into a two barrel manifold with the bores in the same direction as the stock Super Six intake. More details on this in my article.
D'OH! I made mine wide open, but I will explain why in my article as well.
Overall, I agree with CStryker. Unless you are going to convert your intake to a two barrel with the bores running parallel to the engine there simply isn't room to make a proper two barrel intake manifold from a one barrel, and the effort in converting it to a four barrel doesn't justify not buying a used one.
PostPosted: Mon May 08, 2006 12:32 pm
Found this just today, during a search for info on MP intakes, so sorry it is being resurrected.
Found an MP 2 bbl at the Seattle show this weekend. Didn't buy it, but I did look at it pretty close. It was aluminum and said MOPAR on it. The carb orientation was 90 to the Super Six stuff.
Not trying to argue, just found it interesting.
Maybe I should have bought it. He was asking $200. I did get his number though.
'15 Chrysler 200S V6
PostPosted: Mon May 08, 2006 12:55 pm
Ok, now I am starting to doubt my memory. Now, I'm not sure how it was orientated. I'm pretty sure it was different than a standard 2 bbl (he had a cast iron one of those as well), but I might be wrong.
PostPosted: Mon May 08, 2006 1:23 pm
The one and only Mopar Performance 2bbl intake has the carb mounted perpendicular to the axis of the engine, just like the factory 2bbl intakes. Here's a pic of the MP 2bbl intake:
Just like the one on my '62 Lancer
Donno what you saw at that swap meet!
PostPosted: Mon May 08, 2006 2:36 pm
Yep, looked just like that. Like I said, I am doubting my memory now, so I am probably wrong. Seemed like it was 90 degree to that, but probably not.
Think it's worth $200? Think a 2bbl would work on a turbo? :twisted:
