It is currently Sun Nov 22, 2026 3:54 am
PostPosted: Wed Jan 25, 2006 9:46 am
I am rodding my '82 D-150 225. Hooker headers, shaved head, Clifford cam, now turning my attention to intake. All else being equal, what is the theoretical difference in performance between, say, a Holley 2-barrel on a Mopar intake manifold and an Offy dual 1-barrel setup? The goal is lots of torque.
Thanks,
Dave
PostPosted: Wed Jan 25, 2006 10:10 am
Well, from what i understand about throttle bore dimensions, port velocity, and low end torque (which is not very much), if it were me I would go for the Offy dual one barrel intake and run a Carter BBS or the large bore Holley 1920 carbs. Better fuel distribution too on the Offy.
PostPosted: Wed Jan 25, 2006 5:05 pm
I've been looking at those myself and may know where I can pick one up when I'm ready in a few months. My only concern is how to hook up the choke linkage. I'm sure a manual choke could be rigged up but I'd rather have the automatic choke and I'm not anxious to tolerate the cold driveablility problems of a chokeless engine on a street car. It looks like the choke pocket is cast into the intake but as far as I can see it would only operate on one carb... is that sufficient? Bear in mind, I've never actually seen one installed so I'm just going by what I can see in pictures.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Jan 25, 2006 5:44 pm
See Here and Here.
PostPosted: Thu Jan 26, 2006 4:38 am
See Here and Here.
Cool! I've saved those links for future reference. I was tryin to picture in my mind (such as it is) some kind of bell crank linkage but this is certainly simpler. I may have more questions about the electrics if and when I decide to acquire the manifold.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Jan 26, 2006 8:59 pm
Car Model: 1962 Lancer 770
i've also seen the choke pocket relocated to line up with the rear carb (DD did that) on 63Dart's car. I don't run a choke at the moment, and haven't had too much trouble. Once I get my air cleaners straightened out, I'll setup a choke.
MJ
PostPosted: Fri Jan 27, 2006 9:24 am
i have used that intake with holley 1945s for a few years with no choke and haven't had any start/idle problems. offy says to use just one choke and it should be fine though. don't early/mid 70s slants use a divorced electric choke? may be another option.
-james
PostPosted: Fri Jan 27, 2006 10:57 am
The electric kit looks like a good way to go. It wouldn't be too difficult to fabricate a mounting plate so that it would line up with the rear carb.
The MoPar electric choke coils still had to mount down in the choke pocket on the exhaust manifold; it looks to me that fabrication would be much more difficult.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
