It is currently Tue May 19, 2026 12:27 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Thu Jun 21, 2001 2:23 pm
Can someone furnish or direct me to a picture showing the original Hyper-Pak carburetor throttle linkage arrangement?
Ken_Sharp@bramco.com
PostPosted: Sat Jun 23, 2001 10:15 am
: Can someone furnish or direct me to a picture
: showing the original Hyper-Pak carburetor
: throttle linkage arrangement?
Ken,
I have some stuff on the Hyper Pak linkage but need some time to pull it out, scan it in and post.
Do you have a Hyper Pak comming together? What year car / chassis type? Are you OK with using a cable throttle linkage?
Keep checking back, I will try to get this done in the up-comming week, I will post a new message once I have it all pulled together.
PostPosted: Sat Jun 23, 2001 10:33 pm
Doug, appreciate the offer. I've a 67 Cuda notchback, 4-sp, 3.55 sure-grip, head milled w/Ford 300 valves, original Hyper-Pak spec Mellings cam and Clifford's (your's!?) intake manifold & Carter 4bbl. Cable throttle is stock on the car, so I'd prefer a cable version. Thanks for the assistance.
ksharp@iglou.com
