It is currently Sat Nov 21, 2026 5:25 pm
 Post subject: msd coil
PostPosted: Tue Jan 31, 2006 5:18 pm
ok i put an msd blaster 2 coil on about 2 months ago before my rebiuld and it would not run without a ballast resistor
sounds normal right
well after i rebiult my engine it had to bypass the resistor and now she will run
any thoughts on this
is there something wrong or what
PostPosted: Tue Jan 31, 2006 7:10 pm
Remind us what kind of ignition you're running. Chrysler electronic, GM HEI, something else?
PostPosted: Wed Feb 01, 2006 10:25 am
i am using the stock 74 chrystler electronic ignition also have not yet upgraded to the oragne box so i dont know what would be going on?
 Post subject: coil
PostPosted: Wed Feb 01, 2006 12:04 pm
There isn't that much difference between the stock and orange Mopar box, and the metal can MSD coil isn't all that different from a stock coil. I've run an MSD can-type coil for years with a stock (Ford) electronic ignition w/o any problem.
I have seen brand new coils that just were plain defective and wouldn't make a good spark or would arc inside and fry ignition boxes in short order.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
