It is currently Wed Sep 30, 2026 10:40 am
 Post subject: Headers
PostPosted: Sun Feb 05, 2006 6:52 pm
Can you run headers on a stock 225 /6? Or do you have to upgrade to a different intake for the headers to fit? (I am going to get the Clifford Headers if that matters)
PostPosted: Sun Feb 05, 2006 7:17 pm
Headers will work fine on a totally stock engine. However you might find more improvement by richining the carb slightly.
 Post subject: headers?
PostPosted: Sun Feb 05, 2006 7:25 pm
Ok, since I am going to get the headers from clifford I have another question. Do I need the High start headers or the low start headers? I have a 1973 Plymouth Scamp with a 225 stock.
Thanks, Kyle
PostPosted: Sun Feb 05, 2006 8:13 pm
High starter. The low starter is mostley on some trucks. The way to determine the difference is; high starter is above the oil pan/block mating line. Low starter is below the oil pan/block mating line.
PS: what part of Florida are you from?
 Post subject: Florida
PostPosted: Mon Feb 06, 2006 6:51 am
Hey I am from central Florida. Polk county near orlando.
PostPosted: Wed Feb 15, 2006 12:53 pm
can you still get new headers from clifford?
PostPosted: Wed Feb 15, 2006 1:25 pm
Sure you can, but Dutra Duals are better on the street (and the vendor's a whole hell of a lot nicer.)
