It is currently Sun Jun 14, 2026 6:30 pm
PostPosted: Sun Dec 25, 2005 11:11 am
Seems to me that if you make the shaft smaller you reduce the area of the oil bushing surface; with the increase load of long ratio rockers I would be concerned about premature wear. If you could come up with needle bearings in the rocker it might be better. As far as performance goes, the guys over at Dodge Truck World put high ratio rockers in the Magnum engines all the time and swear that it makes a lot of difference. But, they usually have put some time and effort into optimising intake and exhause flow first and the Magnum is a more modern design which might lend itself to such teaks a little better than the slant.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Dec 25, 2005 12:00 pm
How much will 1.6 rockers pick you up at the track?
I'll let Ron Parker tell ya.
http://slantsix.org/forum/viewtopic.php ... kers#12666
Slant Cecil
 Post subject: roller rockers
PostPosted: Tue Dec 27, 2005 12:17 pm
SSRN National Champion
just ordered a set of 1.5 roller rockers from cox brothers and they have gone up to 500.00 a set.
PostPosted: Tue Dec 27, 2005 1:52 pm
Well, I won't be buying any of them.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Dec 31, 2005 4:22 pm
i just bought a set from rocker arm specialtist direct for $420 1.6 ration
 Post subject: retrofitting
PostPosted: Fri Feb 10, 2006 8:23 pm
So the actual problem with retrofitting a set from a small block would be
the length of the rocker arm itself??
 Post subject: Roller Rockers
PostPosted: Fri Feb 10, 2006 8:45 pm
Summit web site lists roller rockers by Crane. P/N CRN-66515-2, $63.69/pr.
 Post subject: Re: Roller Rockers
PostPosted: Fri Feb 10, 2006 8:58 pm
Those are roller lifters/tappets not roller rockers.
So if you can get roller lifters, where to you get the roller cam to go with it, and is there enough oil down there for the roller to work.............
 Post subject: Roller rockers
PostPosted: Sat Feb 11, 2006 7:32 pm
:oops: Ooooops! Shouldn't try to think late at night. Have had lifters on the mind this week.
PostPosted: Sun Feb 12, 2006 5:26 am
Pretty sure, Cox Bros has roller cams available, for the slant.
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
