It is currently Tue May 19, 2026 1:58 am
 Post subject: Tie rod switch
PostPosted: Tue Feb 07, 2006 9:44 pm
so i want to switch to the bigger tie rods
i ordered two of ES352R, ES355RL and the sleeve ES440S.
I'm just hopeing i didn't goof and order the wrong parts.
PostPosted: Wed Feb 08, 2006 6:43 am
That's what I used in a '64 Valiant.
Here's a previous discussion:
http://www.slantsix.org/forum/viewtopic ... e&start=15
PostPosted: Wed Feb 08, 2006 2:29 pm
ok i feel a little better that i have got the rights parts but whats up with ES355L is this the same has ES355RL?
PostPosted: Wed Feb 08, 2006 8:00 pm
I saved the labels. Moog ES440S, ES352R, and, yes, ES355RL.
PostPosted: Fri Feb 10, 2006 2:00 pm
ok i got my parts and they look just look those in your picture. but now i goofed i was playing with them and for got what one was witch . so what one goes inner and outer?
PostPosted: Fri Feb 10, 2006 10:07 pm
ES355RL is inner. I think it's the left-hand thread.
ES352R is the outer. I think that's the right-hand thread.
It doesn't make a lot of difference, as long as you are consistent, and can keep straight on which way to turn each to shorten or lengthen during alignment.
 Post subject: Parts is Parts
PostPosted: Fri Feb 10, 2006 10:09 pm
The ones with Right Hand Threads for the sleeve are the Outer (352R)
The ones with Left Hand Threads are Inner (355RL).
PostPosted: Sat Feb 11, 2006 7:02 pm
When you pull the old tie rods, try not to disturb the length much. Then adjust the new set to match the old length. It's hard to get it exactly right, but it'll get you in the ballpark. Also, try to get the same amount of thread showing on either end of the sleeve.
 Post subject: Re: Tie rod switch
PostPosted: Sun Feb 12, 2006 6:17 am
where did you get them and how much did you pay for?
Juan Ignacio Caino
PostPosted: Mon Feb 13, 2006 1:35 am
0 No Vehicle Specified
MOOG ES355RL $ 19.04 2 $ 38.08
MOOG ES440S $ 14.22 2 $ 28.44
1977 CHRYSLER LEBARON 5.2L 318cid V8 2BBL (G)
MOOG ES352R $ 18.74 $ 0.00 2 $ 37.48
Shipping $ 8.74
Order Total $ 112.74
I got them from http://www.rockauto.com/
did i pay to much you think? i noticed that they have some good prices on some things and a little higher on other parts. i just placed my order for rear drums i noticed there $96 cheaper then my parts store. just hope there has good has the rods i got
PostPosted: Mon Feb 13, 2006 5:42 am
seems good... I'll check on rockauto
I think I remember checking on firmfeel and their set of upgraded tie rods was about 100 bux too... they just have the reputation of being pricey but actually some products are priced about the same as other stores...
Juan Ignacio Caino
PostPosted: Mon Feb 20, 2006 3:11 pm
Car Model: 1962 Lancer 770
No I think firmfeel wants about $175 for these when I looked last time. I thought about doing this as part of my front end swap, but I think I'll just have a welder close the seam on my existing ones and call it good enough.
MJ
