It is currently Wed Sep 30, 2026 5:12 am
 Post subject: True TDC
PostPosted: Thu Feb 16, 2006 10:27 am
What is the best way to find true TDC? The methods I've seen all use a dial indicator which I don't have, but if that's the only or best way I'll go invest in one. I want to measure my piston - deck height so I want to be as accurate as possible. I know I'll need a dial indictor when I go to set up the cam but if I can wait until then it would be better. (Wifee's getting nervous.) :roll:
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Feb 16, 2006 10:44 am
What/how are you planning on measuring deck height? Just rotate the engine in very small increments, until you get the smallest reading.
PostPosted: Thu Feb 16, 2006 10:56 am
Its pretty easy to visually establish TDC. The eye can detect TDC while rotating the crank.
On a slant the piston is at TDC for a surprising length of time.
If you are getting a little older (as am I) and cant see as well as you would like a finger can detect minute increments. Rotate crank with fingure just touching piston....you can feel it "leave" the finger as you roll past...roll back till it "touches"....roll away till it leaves....roll back...etc etc.
I put my index fingure nail on the deck with my finger tip extended into the bore. This steadies the finger. A dial indicater is good...if you can read it.
PostPosted: Thu Feb 16, 2006 2:30 pm
I will be using a dial caliper to measure the depth. The one I have should be accurate to .001". I want to know the actual deck height relative to the piston top but even more than that I want to get the difference, if any between #1 and #6 so that I can get the block squared if necessary. The ultimate goal is to get the compression ratio up to around 9 or 9.5:1 so if the block needs to be trued then I'll know how and how much to have it machined. The rest will be taken off the head after the valve work is done.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Feb 16, 2006 4:25 pm
That will work. Do like Sandy said, then use the dial caliper, as you "rock the engine slowley, till you get the smallest measurement.
PostPosted: Thu Feb 16, 2006 5:37 pm
In other words, put the plunger down in the bore with it just BTDC then roll it over to ATDC while holding the caliper firmly against the deck surface. That should work, and for good measure I'll repeat it to be sure I'm getting consistent readings.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 15 guests
