It is currently Sun May 17, 2026 12:43 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 15 posts ]
 Post subject: TRW pistons
PostPosted: Fri Jul 06, 2001 8:12 am
I was just checking inventory at Federal Mogul on the TRW forged pistons that we have left for slant 6 engines and thought I would share it with you. The results are as follows:
L2125F Std.- 6 pistons
L2125F .030"- 41 pistons
L2502F Std.- 56 pistons(2.2L with 198 rods)
L2502F 100mm- 4 pistons
jharri2@fmo.com
 Post subject: Re: TRW pistons
PostPosted: Fri Jul 06, 2001 2:05 pm
: I was just checking inventory at Federal Mogul
: on the TRW forged pistons that we have left
: for slant 6 engines and thought I would
: share it with you. The results are as
: follows: L2125F Std.- 6 pistons
: L2125F .030"- 41 pistons
: L2502F Std.- 56 pistons(2.2L with 198 rods)
: L2502F 100mm- 4 pistons
OHHHH Charlie: bust out the check book ;)
beardliz@msn.com
 Post subject: Re: TRW Forged Pistons
PostPosted: Fri Jul 06, 2001 4:06 pm
These are FORGED Pistons at a reasonable price. I have used both types and they are strong units. (also a bit heavy weight wise)
The 2125F uses the 6.700 225 con rod, the 2502 must be used with the 7.001 long 198 con rod.
I show this piston in my stroking article.
PostPosted: Sat Jul 07, 2001 9:30 am
: OHHHH Charlie: bust out the check book ;)
No kidding. Just called Summit, and priced the L2125F+30 pistons. Talk about sticker shock. I used to get them for about $9.00 a piece. They are now just under $300 for a set of six.
Charlie
flturbo6@aol.com
PostPosted: Sun Jul 08, 2001 2:39 pm
where would your compression be at if you used a 2.2 liter or one of the vw 88mm pistons with the 6.700 rod and would milling the block and the head get you back up to a 8 to 1 cp ratio? could this be done?
andrew wagner
: These are FORGED Pistons at a reasonable price.
: I have used both types and they are strong
: units. (also a bit heavy weight wise)
: The 2125F uses the 6.700 225 con rod, the 2502
: must be used with the 7.001 long 198 con
: rod.
: I show this piston in my stroking article.
: DD
PostPosted: Sun Jul 08, 2001 4:06 pm
: where would your compression be at if you used
: a 2.2 liter or one of the vw 88mm pistons
: with the 6.700 rod and would milling the
: block and the head get you back up to a 8 to
: 1 cp ratio? could this be done?
: andrew wagner
Well Andrew, I can tell you this much. Mine with the 198 rods came up with a deck height of -.028" on a stock uncut deck. The 6.7 rod is about .300" shorter so theoretically, deck height would be -.328". You could probably get away with decking the block .125" which would get you back to about -.200" Chop about .090" off the head, and add an -.060" overbore, and theoretically you would be just about right. (This message not to be used for any purpose other than it's original intent)
aschumers@aol.com
PostPosted: Sun Jul 08, 2001 4:23 pm
: Well Andrew, I can tell you this much. Mine
: with the 198 rods came up with a deck height
: of -.028" on a stock uncut deck. The
: 6.7 rod is about .300" shorter so
: theoretically, deck height would be
: -.328". You could probably get away
: with decking the block .125" which
: would get you back to about -.200" Chop
: about .090" off the head, and add an
: -.060" overbore, and theoretically you
: would be just about right. (This message not
: to be used for any purpose other than it's
: original intent)
i hacked .145 off my deck on an angle, and didn't hit water! it still runs.....
beardliz@msn.com
PostPosted: Sun Jul 08, 2001 6:42 pm
that gives me some ideas! thank you! I am just trying to get around using 198 rods since they are hard to find.
andrew wagner
: original intent)
PostPosted: Sun Jul 08, 2001 7:30 pm
: that gives me some ideas! thank you! I am just
: trying to get around using 198 rods since
: they are hard to find.
: andrew wagner
this may not be a feasable alternative to all parties: instead of doing 198 rods and 2.2 pistons i decked the block .145 the surfacing machine was much closer than the rods and pistons at the time.
beardliz@msn.com
PostPosted: Mon Jul 09, 2001 11:24 am
I would get the 225 pistons and trim or machine a dish into these to adjust the CR to 8 to 1. These pistons have a thick head so there is lots of material there to work with.
PostPosted: Mon Jul 09, 2001 6:04 pm
: I would get the 225 pistons and trim or machine
: a dish into these to adjust the CR to 8 to
: 1. These pistons have a thick head so there
: is lots of material there to work with.
: DD
Do the 225 pistons have enough material to be machined down far enough to be used with the 198 rods? I am looking for about 12 to 1 compression and I have a set of 198 rods. THANKS! Darrin
dartman225@webtv.net
PostPosted: Mon Jul 09, 2001 6:20 pm
: Do the 225 pistons have enough material to be
: machined down far enough to be used with the
: 198 rods? I am looking for about 12 to 1
: compression and I have a set of 198 rods.
No, there is not enough material on the 225 piston to do that.
Go take a look at the "Stroking the SL6" article I have posted in the article section, the "flat top" 2502 2.2 Forged piston will give you mid 11 to 1 CR and then you could mill the head / block for the rest.
PostPosted: Mon Jul 09, 2001 7:48 pm
did you have anything done to the push rods since you milled the block?
andrew wagner
: this may not be a feasable alternative to all
: parties: instead of doing 198 rods and 2.2
: pistons i decked the block .145 the
: surfacing machine was much closer than the
: rods and pistons at the time.
PostPosted: Tue Jul 10, 2001 4:33 pm
: No, there is not enough material on the 225
: piston to do that.
: Go take a look at the "Stroking the
: SL6" article I have posted in the
: article section, the "flat top"
: 2502 2.2 Forged piston will give you mid 11
: to 1 CR and then you could mill the head /
: block for the rest.
: DD
Will a 1.78 intake and 1.50 exhaust valves fit in a .045 oversized bore? THANKS! Darrin
PostPosted: Wed Jul 11, 2001 4:59 am
: Will a 1.78 intake and 1.50 exhaust valves fit
: in a .045 oversized bore? THANKS! Darrin
The 1.78 is not a problem, the 1.50 exhaust will need to be checked, if the head / valve guides are well centered over the chambers, the 1.50 will clear. The exhaust side is close so everything must be checked for proper clearance.
The biggest valves I have put into a SL6 were 1.875 Int. and 1.540 Ext. on a 3.5 bore. (.100 overbore)
