It is currently Thu Jan 01, 2026 11:08 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Jan 27, 2006 8:37 pm
My 69 Dart was done this way ....twice a year for a decade. I used Safety Yellow....Tremclad.....foam roller...mineral spirits.
I like to duct tape over the rust holes first.
PostPosted: Fri Jan 27, 2006 9:23 pm
Wow. That picture makes me miss Alaska. Good looking Dart. How did the rust holes hold up?
PostPosted: Sat Jan 28, 2006 2:03 am
Hey Sandy, why so often? If it only holds up well enough to last 6 months it loses its appeal for me. I thought this would be a good, cheap, quick, easy way to paint the GodsRods Duster race car and have the kids be involved in the painting, but maybe not.... :? :?:
PostPosted: Sat Jan 28, 2006 6:43 am
PostPosted: Sat Jan 28, 2006 11:26 am
It was painted twice a year because I needed to tape over rust holes twice a year. The paint does fade a little ....and its easier to reroll than to rub it out. I bet there was 3 gallons of paint on that car.
Better roller painted than multicoloured when it comes to the DoT!
PostPosted: Sat Jan 28, 2006 11:05 pm
I painted my steel rims over the summer with the semi-flat black. I used a brush and have brush lines, but I didn't use the mineral sprites to thin the paint. The paint is really to thick without the thinning. Years ago I used the red oxide heavy rust printer as the base priner on a car. It worked just fine when I sprayed regular auto paint over it.
PostPosted: Mon Jan 30, 2006 6:02 am
I tried his method over the weekend on a spare trunk lid I had lying around. I did way less than the required prep. It had cracked old enamel on it I lightly scuffed it and wiped it off with an old tee shirt. Applied the paint in a few coats with no sanding between them. I let it dry overnight saturday and sanded and polished it sunday afternoon. It looks amazingly good all things considered. I even tried the chip test and the only place it would chip is when the paint underneath would chip also. It looks like I've found the cheapo 1 panel at a time paint method for my v100.
PostPosted: Wed Feb 22, 2006 9:47 am
You know I'm going to try and paint my pick-em-up this way. I would like to go with a flat black for 2 reasons; 1) because of the dings in the body and 2) I not have to worry about the scratches so bad. I want to put a protectant over the paint. Wouldn't clear make the flat glossy, if so, what can I cover the flat black with?
Thanks
85' D100
225cid
A833OD
PostPosted: Wed Feb 22, 2006 1:10 pm
Roll on truck bed liner
PostPosted: Wed Feb 22, 2006 5:28 pm
wow, thats amazing if i told my dad i wanted to paint a car with a roller he would laugh at me, hell i probably would to, very awesome find/post :lol: 8)
Cuda Progress :D
The dart as it sits now :(
PostPosted: Wed Feb 22, 2006 7:29 pm
Wouldn't that be a little too thick with the additive and all? I know some of the bed liner sprays use recycled rubber.
85' D100
225cid
A833OD
PostPosted: Thu Nov 06, 2008 7:24 am
. Wouldn't clear make the flat glossy, if so, what can I cover the flat black with? Thanks
You can get satin clear coat, or satan, as we call it in the business. I was thinking about the satin over a flat black, also. I thought it would be fun to hit the clearcoat with a textured roller, to go for the carbon fiber look. :|
PostPosted: Thu Nov 06, 2008 9:43 am
:lol: :twisted: :evil:
Or you could take that notion to an extreme and cover the whole car with truck bedliner material, like this guy did to his Audi A4. :shock:
(Actually not such a bad idea for a super-tough finish...)
PostPosted: Thu Nov 06, 2008 10:35 am
But — DEAR GOD, THINK OF THE WIND RESISTANCE!!!!! :)
vm
PostPosted: Thu Nov 06, 2008 10:52 am
Yeah, but couldn't it be sanded smooth...?
