It is currently Sun Nov 15, 2026 12:55 pm
PostPosted: Fri Feb 24, 2006 10:20 am
I have been told to look out for a long runner, 4-barrel intake if wanting to upgrade my /6. But I came across a short runner 4-barrel. What are the differences between these two regarding performance, looks, weight, specs, etc. Thanks again in advance...
PostPosted: Fri Feb 24, 2006 10:47 am
Car Model: 1962 Lancer 770
What brand intakes are you talking about? By long runner I guess you mean Hyperpak? The short is an offenhauser, clifford or...? That way you get the best answer possible. What are you hoping to achieve with this motor?
PostPosted: Fri Feb 24, 2006 11:02 am
Trying to achieve durability/reliability because it will be used as a daily driver.
PostPosted: Fri Feb 24, 2006 11:09 am
Daily driver
Then a 2bbl would almost certainly better suit your needs than either of the 4bbl pieces you're asking about.
PostPosted: Fri Feb 24, 2006 11:21 am
Any reliable brand with a good reputation that you recommend?
PostPosted: Fri Feb 24, 2006 12:02 pm
Super six intake (two barrel) with a carter BBD from a late 70's aspen/volare/diplomat. Look in the articles section off the main page all the information you need for the swap is there.
PostPosted: Fri Feb 24, 2006 12:13 pm
good looking out
