It is currently Sat Nov 07, 2026 3:04 pm
 Post subject: Oil pump idiot light
PostPosted: Tue Feb 28, 2006 12:36 pm
I need to know where on my oil pump the idiot light is. Is it threaded in under the filter on the extreme left of the body? On the tip?
PostPosted: Tue Feb 28, 2006 1:05 pm
Online
yes
PostPosted: Tue Feb 28, 2006 10:09 pm
Don't over torque the sending unit!! You can very easily split the pump where the sender threads in if you over tighten it.
Mitch
PostPosted: Tue Feb 28, 2006 10:14 pm
MitchB is right, i know, i learned the hard way :roll:
70 Plymouth Valiant 4dr
PostPosted: Thu Mar 02, 2006 9:52 am
thanks, i just ran a line off of it to my turbo oil feed.
PostPosted: Thu Mar 02, 2006 10:15 am
That may give you oil before it goes through the filter. I'm not sure. You do not want unfiltered oil going to your turbo.
Mitch
PostPosted: Thu Mar 02, 2006 10:33 am
Online
That location is fine. I put a "T" at that point, ran a 1/4 line from there to my turbo, and a pressure gauge line, off the other branch, and never had a problem.
