It is currently Wed Nov 11, 2026 12:56 pm
 Post subject: Specs
PostPosted: Thu Mar 02, 2006 6:10 am
hello does anyone know all the torque specs for all the bolts in the 7 1/4 rear on a 74 dodge dart (2.76 case with roll pin 9 bolt cover)
thanks
Dustin
PostPosted: Thu Mar 02, 2006 7:05 am
Cap bolts:...........................40 ft/lbs.
Ring gear bolts:...................55 ft/lbs. (L/H thread)
Pinion flange nut:.................210 ft/lbs (min)
Cover bolts:........................250 in/lbs.
Axle retainer nuts:...............35 ft/lbs.
Driveshaft (U-joint) bolts:.....15 ft/lbs.
D/W
If it ain't broke, fix it!
