It is currently Sun Nov 08, 2026 12:43 am
 Post subject: Slanted floats.........
PostPosted: Thu Mar 02, 2006 1:45 pm
Car Model: Toad Wagon
Gentlemen,
Well, it looks like the committee's going to go with my idea for a slant to power our Rose Parade float's animation set. The engine I have for this is a stock peanut head 225. One of the requirements will be the lowest profile possible. To that end I'm looking for one of the side draft single set-ups used on the motor homes and components for a clutch set up todrive the hydro pump.
Any info on this carb would be appreciated. The searches I've run so far haven't helped much, due at least partially to a lack of correct references I think.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Mar 02, 2006 2:42 pm
Check your local boat junkyards. Chrysler made a marine application slant six inboard motor that actually laid flat on its side. I believe it was called the "Royal Crown 225" or the space saver package. I have a article that talks about ti I will post when i get home tonight.
 Post subject: Hey Reed!
PostPosted: Fri Mar 03, 2006 6:42 am
http://www.slantsix.org/forum/viewtopic ... ght=marine
I enjoyed that article as much as anything I've ever seen posted. Thanks again, pardner.
Last one out , turn off the light
