It is currently Sun Nov 08, 2026 10:36 pm
 Post subject: Accelerator cable length
PostPosted: Fri Mar 03, 2006 5:10 pm
Could somebody tell me the length of the supersix throttle cable? I am thinking about getting one the stainless steel throttle cable kits instead of digging through a junkyard.
Also, with Lokar's kickdown cable for the 904 TQ, will I have to change the lever on the side of my transmission? Or does it just bolt right on and come with its own lever?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Mar 03, 2006 5:38 pm
You remove the pin that holds the stock linkage to the lever. Then on the end of the lokar cable theres a stud that goes through the lever then nut on the other end that holds it to the lever. The lever itself stays on the transmission.
