It is currently Fri May 15, 2026 2:35 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: Harmonic Balancers
PostPosted: Sun Jul 15, 2001 3:17 am
Hey guy's I just tore down my 64 to put a new cam in it(clifford 260)and found alot more than I bargianed for. To make a long story short I'm about to have the long block rebuilt(1.78" In 1.4" Exh ported and bench flowed head, rotating assemebly balanced, and stock compression for turbo I'm putting together)and I need a new harmonic balancer. My old one broke when I pulled it off(casting split) and all the places I've gone say that they don't exist new , or rebuilt any more. I think they are full of s**t, but haven't yet forund a supplier for a stock or rebuilt one. Can you point me in the right direction?
andyman225_99@yahoo.com
 Post subject: Re: Harmonic Balancers
PostPosted: Sun Jul 15, 2001 7:53 am
: Hey guy's I just tore down my 64 to put a new
: cam in it(clifford 260)and found alot more
: than I bargianed for. To make a long story
: short I'm about to have the long block
: rebuilt(1.78" In 1.4" Exh ported
: and bench flowed head, rotating assemebly
: balanced, and stock compression for turbo
: I'm putting together)and I need a new
: harmonic balancer. My old one broke when I
: pulled it off(casting split) and all the
: places I've gone say that they don't exist
: new , or rebuilt any more. I think they are
: full of s**t, but haven't yet forund a
: supplier for a stock or rebuilt one. Can you
: point me in the right direction?
Clifford has a raceing one but it's over $300 bucks............ I ran across a rebilder when I was looking for pulleys I'll see if I can find it again and post it
PostPosted: Sun Jul 15, 2001 8:07 am
You can get a Fisher from clifford or use a big block one from summit, such as a fluiddamper. All you have to do is change to a differnt seal. A big block one may work I dont know about the outside dia. off hand.
Will
slantsix@netzero.net
PostPosted: Sun Jul 15, 2001 8:14 am
Here's some rebuilders some do have stock on hand
Winslow Mfg; 5700 Dean Ave; Raleigh NC 27604; 919-790-9713
Damper Dudes; 5509 Cedars Rd #2; Redding CA 96001; 800-413-2673 (orders)
or 916-244-7225 (info)
Damper Doctor; 1055 Parkview Ave; Redding CA 96001; 916-246-2984
Hope this helps
 Post subject: Damper Doctors
PostPosted: Sun Jul 15, 2001 8:41 am
Damper Doctors
1055 Parkview Avenue
Redding, CA 96001
They are a damper rebuilder. Dennis
aschumers@aol.com
