It is currently Thu May 14, 2026 10:50 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Max RPM before BOOM!
PostPosted: Mon Jul 16, 2001 4:34 pm
So whats the max you have wound a stock rod 225?
Whats the max anyone has wound a 198 rod 225?
cralt@hackme.dhs.org
 Post subject: Re: Max RPM before BOOM!
PostPosted: Mon Jul 16, 2001 5:27 pm
: So whats the max you have wound a stock rod
: 225?
: Whats the max anyone has wound a 198 rod 225?
Stock rods...... but balanced.... 6500rpm
PostPosted: Mon Jul 16, 2001 11:06 pm
: 225?
6500 RPM for a 6.7" rod
7000 RPM for the 7" rod combo.
Both were rebalanced.
I think the big advantage to the "long rod" engine is mostly from the lighter pistons and the thinner "low friction" ring set you get with this combo.
A light piston sure helps con rods live longer.
