It is currently Fri Nov 27, 2026 12:12 pm
PostPosted: Mon Mar 13, 2006 1:33 pm
When you order a new front drum for a 66, do they come with the hub attached or do you need to have it mounted on a hub?
PostPosted: Mon Mar 13, 2006 7:33 pm
Im 99% percent sure all you get is the drum,I know thats all you get with the 9 inch drum. Be careful removing the drum from the studs because they are swagged on from the front.I ended up grinding the heads off the studs from the back and driving them out the front of the drum and installing new studs.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
