It is currently Fri May 15, 2026 3:05 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: C body axles
PostPosted: Sat Jul 21, 2001 6:12 pm
Do '72 8 3/4 Imperial have 4 1/2" bolt circles. I think some of the older Imps had 5". I want to find an axle set that I can have resplined for my A-body '71 Dart. These Imperial axles are 29" long and are tapered. I searched for information on the Moser services, are these axles OK to use?
Tim.Keith@billserv.com
 Post subject: Re: C body axles
PostPosted: Sun Jul 22, 2001 2:36 am
Yes, 72 Imperial,8 3/4 is 5 on 5".
PostPosted: Mon Jul 23, 2001 4:45 pm
I pulled 3 sets of 8 3/4 axles from trucks and a van. They're all the same as the '72 Imperial, the trucks are 1/2" or so longer, the truck axle had yellow paint on them. They are necked down, but I think there is plenty of material
for resplining by Moser.
"Green" bearings are just ball bearings, right ? What is the advantage vs the needle bearings ?
: Yes, 72 Imperial,8 3/4 is 5 on 5".
