It is currently Wed Dec 31, 2025 6:21 am
PostPosted: Fri Mar 24, 2006 5:44 pm
I am getting ready to reinstall the intake and exhaust manifolds on my car. My question is, do I torque the intake to exhaust manifold bolts prior to installation or do I install the manifolds on the engine, torque them to 10 ft lbs (sez so on the manifold) and then the torque down the intake to exhaust manifold connector bolts?
I saw this in a Hayne's manual (I know, I know) and it made me wonder, which way is right? By the way, what is the correct torque spec for the intake to exhasut manifold connector bolts?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Mar 24, 2006 6:00 pm
Carefully read the Manifold Installation article in the "Articles" section of this site. You loosely install the three intake-to-exhaust fasteners (finger tight), then install the manifolds as an assembly onto the head, then torque the manifold-to-head stud nuts, then torque the three connecting fasteners.
PostPosted: Fri Mar 24, 2006 7:49 pm
hey dan
what i did on mine was i bolted the intake and exhaust down and torqued them, then i had my machinist surface the mounting faces on the manifolds and then i bolted them on
i thought by doing it this way was a good way not to have a leak in between the two manifolds which i heard was a common spot for leaking
what do you think about this method?
Thanks Dan, I had read that article god knows how many times but had never noticed that part. Found it now though.
82 D150-225/727
PostPosted: Sat Mar 25, 2006 8:26 am
off topic.......but thats a sweet looking duster there jeb.
Users browsing this forum: Ahrefs [Bot] and 9 guests
