It is currently Sat May 16, 2026 10:27 am
PostPosted: Mon Mar 27, 2006 9:30 am
Car Model: 1962 Lancer 770
In the process of rebuilding my calipers, I noticed a small dent that looks like it was caused by a chisel or something. It deforms the dust boot seal just enough to force it to push into the piston more than it should. I am worried it will hang the piston up (it was hard to install, and harder still to get back out.
Picture 1: http://tinyurl.com/ktz9o
When I removed the boot, here's what I saw:
Picture 2: http://tinyurl.com/k7m4f
The question is, should I try and use a thin flap disc on a dremel to remove the material that is dented downwards to make this seal up correctly? I'm not sure what to try or what tool to use. Being cast, I can't see bending it very easily without deforming something else.
Thanks!
Menko
PostPosted: Mon Mar 27, 2006 9:32 am
Yep, your Dremel idea will work fine. Just proceed carefully.
PostPosted: Mon Mar 27, 2006 9:35 am
ok just wanted to be sure I wasn't fooooooobar! :D
Off to try
PostPosted: Mon Mar 27, 2006 5:14 pm
Well.... now that's an entirely different question... ;)
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Mar 27, 2006 8:34 pm
Yeah the true colors appear quickly don't they ;)
MJ
