It is currently Tue May 19, 2026 10:41 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: concrete raceblock?
PostPosted: Wed Jul 25, 2001 5:38 am
i know this is weird, BUT if i want to put block hardener in the block, but still retain somekind of waterpassages in it, what would be the best thing to use? you know i would like to strengten the block in the cylinder area, and have small water circulation inside the block...
any ideas?
http://homepage.mac.com/jyrie
jyri.eramaa@jwt.fi
PostPosted: Wed Jul 25, 2001 3:29 pm
: I know this is weird, BUT if i want to put
: block hardener in the block, but still
: retain somekind of waterpassages in it, what
: would be the best thing to use? you know i
: would like to strengten the block in the
: cylinder area, and have small water
: circulation inside the block...any ideas?
There is some info. on this subject in the SL6 Block article. Mostly at the end of the story. <A HREF="http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm">http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm</A>
Just don't fill it all the way to the top and use clay or wax to keep the filler out of the waterpump enty area. I have filled blocks about 1/3 the way and cooling does not seem to suffer at all.
PostPosted: Wed Jul 25, 2001 11:59 pm
: There is some info. on this subject in the SL6
: Block article. Mostly at the end of the
: story.
: <A HREF="http://www.slantsix.org/articles/dutra- ... cks.htm</A>
: Just don't fill it all the way to the top and
: use clay or wax to keep the filler out of
: the waterpump enty area. I have filled
: blocks about 1/3 the way and cooling does
: not seem to suffer at all.
: DD
is the block weaker in the bottom?
i would think that there is more pressure in the combustion area, but in the lower part the piston is trying to do more of sideways movement...well thanks! i have to try this....
jyri.eramaa@jwt.fi
