It is currently Sat May 23, 2026 1:43 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: cecil county drags
PostPosted: Sun Jul 29, 2001 8:01 am
I was down at cecil county drag way on saturday here's how I did!
60ft 1/8 mph 1/4 mph
2.066 9.54 70.76 15.12 87.85
2.08 9.66 70.12 15.29 86.97
2.16 9.77 69.97 15.41 86.83
I was very pleased with the car it run smooth. The 15.12 was unexpected I was thinking about 15.4 or 15.5. before I went down I jetted the carb up one # to a 67. I must be starving it a little. for anyone that does not know, I am running a stock slant six 225 with a to3 turbo from a 2.5 four banger, 3" exhaust,four barrel holley,and a chome ecu with msd coil and timing control.
andrew wagner
 Post subject: Re: & Turbo SL6 Results
PostPosted: Sun Jul 29, 2001 10:37 am
Way to go Andrew!
Take a "stock" 225 SL6, add a TO3 turbo and Holley 4 BBL to "feed-it" and run low 15's, I like it!
What rear gear ratio are you running? any Posi back there? I would think that traction is starting to become an issue with the car but I'm sure your "blowing some minds" with this deal.
Time to give the carb. even more jet??, can you say high 14's??
: I was down at cecil county drag way on saturday
: here's how I did!
: 60ft 1/8 mph 1/4 mph
: 2.066 9.54 70.76 15.12 87.85
: 2.08 9.66 70.12 15.29 86.97
: 2.16 9.77 69.97 15.41 86.83
: I was very pleased with the car it run smooth.
: The 15.12 was unexpected I was thinking
: about 15.4 or 15.5. before I went down I
: jetted the carb up one # to a 67. I must be
: starving it a little. for anyone that does
: not know, I am running a stock slant six 225
: with a to3 turbo from a 2.5 four banger,
: 3" exhaust,four barrel holley,and a
: chome ecu with msd coil and timing control.
: andrew wagner
PostPosted: Sun Jul 29, 2001 4:48 pm
hey doug
I am putting a 650 dp on for next saturday. I run a 8 3/4 rear with 3.55 and a posi. As for traction it is spinning of the line but not more then once around then it hooks. I also put 235 60 14s on to help. when I ran the 15.12 it was at 7 psi.I let you guys know on sunday if I get in the 14s.
andrew wagner
: Way to go Andrew!
: Take a "stock" 225 SL6, add a TO3
: turbo and Holley 4 BBL to
: "feed-it" and run low 15's, I like
: it!
: What rear gear ratio are you running? any Posi
: back there? I would think that traction is
: starting to become an issue with the car but
: I'm sure your "blowing some minds"
: with this deal.
: Time to give the carb. even more jet??, can you
: say high 14's??
: DD
PostPosted: Sun Jul 29, 2001 6:28 pm
: hey doug
: I am putting a 650 dp on for next saturday. I
: run a 8 3/4 rear with 3.55 and a posi. As
: for traction it is spinning of the line but
: not more then once around then it hooks. I
: also put 235 60 14s on to help. when I ran
: the 15.12 it was at 7 psi.I let you guys
: know on sunday if I get in the 14s.
: andrew wagner
That's great Andrew! Keep those results coming. Dennis
aschumers@aol.com
 Post subject: Re: cecil county drags
PostPosted: Sun Jul 29, 2001 7:39 pm
: here's how I did!
: andrew wagner
VERY COOL!!! Keep up the great work. Was this with your in house fabed intake too?
Mike
msimpson@millenicom.com
 Post subject: How far from Buds Creek
PostPosted: Sun Jul 29, 2001 11:21 pm
How far are you from Buds Creek? I may race there sat.
Will
: hey doug
: andrew wagner
slantsix@netzero.net
PostPosted: Mon Jul 30, 2001 10:20 pm
where is bud creek?
asndrew wagner
: How far are you from Buds Creek? I may race
: there sat.
: Will
PostPosted: Tue Jul 31, 2001 6:44 am
Isn't Cecil County Dragway in Budds Creek, Maryland? I raced there once about 1965.
Charlie
: where is bud creek?
: asndrew wagner
flturbo6@aol.com
PostPosted: Tue Jul 31, 2001 4:57 pm
: That's great Andrew! Keep those results coming.
: Dennis
Congrats Andrew. Keep up the good forced induction...
madsenl@caltech.edu
PostPosted: Wed Aug 01, 2001 12:15 am
: asndrew wagner
south Maryland. home of Maryland international dragway. Doesnt matter, not going this weekend. See youall at Wilksboro.
Will
