It is currently Mon Nov 16, 2026 7:25 pm
 Post subject: damper/ waterpump
PostPosted: Mon Apr 03, 2006 8:07 am
77- 225 short block back from the machine shop. Going into 64 Valiant 170. I have a new waterpump on the 170. can I use it on the 225? What about Pullys etc? The damper on the 225 has the damper sandwiched between 2 pullys the 170 has a smaller, narrower single damper/pully. I don't know if it will align with accessories from the 170. The 170 is not yet out of the car. :?:
 Post subject: Re: damper/ waterpump
PostPosted: Mon Apr 03, 2006 9:32 am
Yes.
All directly interchangeable.
With the exception of the timing mark location, the '64 and '72 dampers are identical. The extra pulleys (front power steering and rear A/C) are bolted onto the damper.
Yes, it will.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
