It is currently Mon Jun 15, 2026 4:20 am
PostPosted: Sun Apr 02, 2006 3:41 pm
Hi all :D . I have a 1978 Dodge Aspen with the 225 slant six engine. This evening, I put a new valve cover gasket on it, and let it set idling for about 8 minutes to see if it was going to leak.
It ran perfectly for the 8 minutes, and then just out of no where, it died. I got in it and tried to star it. It would turn over just fine, but would start, it would back fire and black smoke would come from the carbarator the it would hit a time or two and then just turn over.
We tried it for about 20 minutes, and it got to where it would start and then die. We put some more gas in it (the gauge read half a tank). The only other thing that we did was put some STP gas treatment in.
Any thought's as to what it could be? Thanks for any advice,
Tony
PostPosted: Sun Apr 02, 2006 3:43 pm
Sounds to me as if your timing chain has slipped. How many miles are on this engine?
PostPosted: Sun Apr 02, 2006 3:51 pm
The title and the odometer has 34,275. I don't know if it is exact.
Tony
PostPosted: Sun Apr 02, 2006 3:57 pm
Well, take a look at the condition of the whole car. Does it look like a 34k mile car, or a 134k mile car, or a 234k mile car...?
PostPosted: Sun Apr 02, 2006 4:12 pm
How did it run before the gasket replacement? Check for things you may have changed or disconected during the valve cover removal. Did you re-connect the pcv hose?
PostPosted: Sun Apr 02, 2006 4:31 pm
It doesn't look like a high milage car, it has just a few small places with surface rust on it, and all of the undercoating is still there and in great shape. the dash has no crack or fading, the seats are in wonderful condition(the drivers side has a place where a seam has come loose. I don't think that it is off by too much.
The engine is clean, the trunk has the small piece of carpet in it, and the coating is still factory fresh. The spare tire is the original biase ply(though it looks like it might have been put on and ran a few mile. The carpet is in beautiful condition.
Here is the E-Bay auction that it was on:
http://cgi.ebay.com/ebaymotors/Dodge-As ... dZViewItem
http://cgi.ebay.com/ebaymotors/Dodge-78 ... 4180QQrdZ1
It looks like it has been setting for quite sometime, because it had leaves and sticks around the hood, trund and inside the fenders.
It was running without missing a beat, and just all at once died.
Tony
PostPosted: Sun Apr 02, 2006 5:11 pm
Car Model: 1974 W100; 72 Dart
ballast resistor?
sb
PostPosted: Sun Apr 02, 2006 5:27 pm
ballast resistor?
No.
PostPosted: Sun Apr 02, 2006 5:38 pm
I'll check the timing tomorrow. I hate that it did this, as it has been running great :cry:
Tony
PostPosted: Sun Apr 02, 2006 7:44 pm
How long was it sitting????????
Crap/rust from tank could have clogged up fuel filter and/or fuel sock (in tank) or the fuel pump went.......
See if the gas makes it to the carb. Either test for fuel pressure or take the top off the carb. If no fuel pressure or no gas, put some gas directly into the carb bowl before putting the top back on and see if it runs.
PostPosted: Sun Apr 02, 2006 8:05 pm
I agree with Dan on this one. Definitely sounds like jumped timing.
Nylon cam gear strikes again!
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Apr 02, 2006 8:27 pm
The fuel filter was clean, and there is good gas pressure. We took the fuel line off and let it run/pump for about 25 seconds. I forgot to post that. The best that I can get, it was sitting for about a year.
Tony
PostPosted: Mon Apr 03, 2006 2:14 am
Yank a plug and a plug wire, ground the plug to someplace on the engine and have a friend crank it over to see if your getting spark. Hold onto the boot high up, not the plug! Also don't lean up against the car if you try this. Or it could be your ECU, check to see if there is any goo oozing out from under it, they'll die without warning like what your talking about.
70 Dart, 360, 727
PostPosted: Mon Apr 03, 2006 9:18 am
If you determine that your car is firing then try this. Bring the Number 1 cylinder to TDC. Now take the distributor cap off. The rotor should be pointing to the #1 distributor terminal. If it is pointing anywhere else, you have jumped timing.
82 D150-225/727
PostPosted: Mon Apr 03, 2006 10:14 am
That's some great idea's. I'll check each one until we find out what it is.
Tony
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 2 guests
