It is currently Fri Jun 12, 2026 11:14 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Mon Apr 03, 2006 10:58 am
Yank a plug and a plug wire, ground the plug to someplace on the engine and have a friend crank it over to see if your getting spark.
The engine is firing, which means he's got spark. The spark is occurring at the wrong time, which is why he's getting backfire and black smoke out of the carburetor. The engine "tries to start", which means the distributor is probably turning and so probably hasn't got a split drive pinion (though that remains a possibility—pop off the distributor cap and crank the engine to see if the rotor's turning).
The most likely possibility is radically incorrect cam timing, and the most likely cause is a slipped timing chain.
PostPosted: Mon Apr 03, 2006 11:20 am
I had a slant do this to me once and it turned out to be the plastic distributor drive gear had about 3/4 of four teeth in a row sheered off. The car would run fine for about ten minutes, then lose power and stumble, then die. I would crank it for about five minutes and then it would catch and run for a bit, then die, etc... The dist gear would turn the rotor but because of the missing teeth it would gradually slip it totally out of time.
I would also check the coil. I have seen coils that could put out a spark but not run the car.
PostPosted: Mon Apr 03, 2006 12:34 pm
Yeah I read what he wrote too fast, I missed the part about the black smoke and backfiring. I thought it was just dead.
70 Dart, 360, 727
PostPosted: Tue Apr 04, 2006 11:48 pm
My stepdad called and left a message on my answering machine today that he found the problem. Apparently, when we took the valve cover off, we hit a wire, and it got shorted out. I'll call him tomorrow, and see what wire it was. I feel pretty stupid on this problem :oops: , and I did get some good advise. Thanks again to all that helped out,
Tony
PostPosted: Thu Apr 06, 2006 12:15 am
I got the answer to what the problem was.
When we took the valve cover off, there was an ignition wire that got slack pulled in it and was laying on the manifold. When the car ran for the few minutes(that we were waiting to see if the new gasket was going to leak), the motor got hot enough to melt the coating on the wire, and shorted it out.
I hope that is all that it was,
Tony
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
