It is currently Tue Nov 17, 2026 1:39 am
PostPosted: Mon Apr 03, 2006 7:15 pm
I am going to run a MSD 6AL with with this GM module set up. What wire configuration should I buy? Mopar or GM?
PostPosted: Mon Apr 03, 2006 7:30 pm
Neither. Use the mopar electronic distributor, and the MSD wireing, diagram. You do not need any other components, except for a compatable coil.
PostPosted: Mon Apr 03, 2006 8:44 pm
Thanks, Charlie I thought you needed a module even with MSD. So as an upgrade I would use a GM four pin. But you solved my dilemma, thank you!
