| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 69 of 92 |
| Author: | SIX GUN [ Wed Oct 12, 2016 4:33 pm ] |
OK, now you're getting close, I think I'm gonna put the Webber's back on (LOL )!!!! |
| Author: | Greg Ondayko [ Wed Oct 12, 2016 4:45 pm ] |
I have a few more ideas to try.. i need to water the money tree first though. Webers are one of them. Greg |
| Author: | NCDemon1971 [ Sun Jul 09, 2017 10:32 pm ] |
Greg Do you have any pictures of how your oiling system is setup? Thanks |
| Author: | Greg Ondayko [ Tue Jul 18, 2017 8:19 pm ] |
They were all on here until photobucket broke it. Try this http://s299.photobucket.com/user/hyperp ... t=3&page=4 And this http://s299.photobucket.com/user/hyperp ... t=3&page=5 Also watch this video.. it might help. https://youtu.be/P81lzr_Owwk Also i should be at the wilkesboro race this weekend... stop by and see it in person at empire chrysler sat morning. Greg |
| Author: | Greg Ondayko [ Sun Nov 19, 2017 5:05 pm ] |
| Post subject: | Ruster Update 11/19/17 |
Hi guys, I just got done with the engine teardown.. I put the car away after making it to the 3rd round of the fall mason dixon race. Turn out i have a spun rod bearing as i suspected.. and also i found out why i was getting water in the oil.. There were 2 cracks in the bottom of #6 cylinder and 1 crack in #5 cylinder.. So i need to get a new block and another molnar rod. Greg |
| Author: | Ron Hamby [ Mon Nov 20, 2017 5:17 pm ] |
| Post subject: | Re: 1968 Valiant Ruster Racer IRWIN PA |
Gary Bruner was able to order a single rod from K1 this week if you cant find a molinar |
| Author: | DadTruck [ Mon Nov 20, 2017 5:40 pm ] |
Quote: 2 cracks in the bottom of #6 cylinder and 1 crack in #5
any ideas on why the bores cracked,, did you just get 5 and 6 cylinders too thin on the over bore? |
| Author: | Exner Geek [ Mon Nov 20, 2017 5:49 pm ] |
Did you fill your block when you did the overbore? If so how deep? |
| Author: | Greg Ondayko [ Mon Nov 20, 2017 6:34 pm ] |
Quote: Quote: 2 cracks in the bottom of #6 cylinder and 1 crack in #5
any ideas on why the bores cracked,, did you just get 5 and 6 cylinders too thin on the over bore? Do you mean with hard blok? No I did not.. i think i will put more time into this block.. probably a partial hard block fill as well. I have some research to do. I am not sure why it cracked... but this block lased quite a while. 5+ years without too many issues until this. Lots of passes too. Greg |
| Author: | Greg Ondayko [ Mon Nov 20, 2017 6:37 pm ] |
Quote: Gary Bruner was able to order a single rod from K1 this week if you cant find a molinar
Good to know Ron, I was able to get a single rod from tom before.. i just need to match the big end and little end weights. Greg |
| Author: | Rick Covalt [ Tue Nov 21, 2017 4:10 am ] |
Do you remember what clearances you were running? |
| Author: | Greg Ondayko [ Tue Nov 21, 2017 3:38 pm ] |
Stock.. prolly 0.001-0.0015 Machine shop and I agreed to double that rod clearance to 0.003 on the rod journals. Mains were fine. A bit of thrust bearing wear from stalling the conv. so much.. i believe this one does not have the anti balloon plate. Greg |
| Author: | Rick Covalt [ Tue Nov 21, 2017 3:47 pm ] |
Quote: rod clearance to 0.003 on the rod journals.
Yep that should be good. Wonder why it spun? I'm sure Ruster will debut next year better than ever! |
| Author: | Greg Ondayko [ Tue Nov 21, 2017 4:54 pm ] |
Yep it was #4. At least i didnt shoot a rod through the block or oil the track down... Greg |
| Author: | Dart270 [ Wed Nov 22, 2017 3:18 am ] |
I thought that Pittsburgh track racers had to sign a form that they were required to oil down a track at least once each year? Lou |
| Page 69 of 92 | All times are UTC-07:00 |
