It is currently Wed Sep 30, 2026 10:12 am
Post new topic  Reply to topic  [ 521 posts ]  Go to page Previous 1 … 6 7 8 9 10 … 35 Next
PostPosted: Sat Oct 17, 2009 11:38 am
Sounds like a bad module. Did you wire in a relay to power the module? I am thinking that that might have been the problem in my brother's van (see the post above yours). My brother's van would run okay but idled rough and lacked power.
Does it matter if the ignition module is for a v-8, or does it have to be for a six cylinder? I ordered one for a 78 Camaro with a 350.
Someday, I am going to try the swap again, but use a relay and get a high quality ignition module. The one I got was from Autozone and I think it was bad right out of the box.
PostPosted: Sat Oct 17, 2009 12:34 pm
I tried two different relays, Im going to take the module back and see if thats the problem. I guess we'll see from there :roll:
14" Cragar SS wheels
PostPosted: Sat Oct 17, 2009 2:32 pm
I never used a relay on the 3 I have done. It dosent matter to the module how many cylinders there are. I have used V8 modules and one out of a Chevette
PostPosted: Sat Oct 17, 2009 2:37 pm
I recently did the HEI swap on my brother's 83 van with a 225. I used an E-core coil from an 89 Ford van (351 motor).
How do I wire in a noise suppressor for the radio? My brother says he gets bad feedback through the radio when he accelerates. Can I use the factory noise suppressor and just wire it to the (-) lead on the coil?
Also, after I did the switch the cheapo aftermarket tach I installed in his van started reading about 300 RPM too high and occasionally bounces up to around 1600 RPM at idle. The motor still idles at around 750-800 RPM at idle and is steady. Do i just have a crappy tachometer?
The noise suppression capacitor connects to the + terminal of the coil. Does your brother listen to AM a lot?
I'd substitute another tach and check again.
PostPosted: Sat Oct 17, 2009 2:41 pm
Thanks. THe wiring looks like the suppressor hooks into the (-) terminal, but I could be wrong. Anyway, it turns out the noise was coming from a fried radio in the dash. :roll:
I swapped back to a mopar ignition module and the tach problem and idling problem went away. I think I might have wired the HEI wrong or gotten a bad module. :x
PostPosted: Sat Oct 17, 2009 2:43 pm
I just tried to install HEI on my car, and I have everything hooked up right, except that when you try to start it, it idles badly and if you hit the gas it stumbles and sends a column of smoke out the carb, then dies. So I switched the two wires that go from the module to the dist around, it will not start and sends smoke out the carb. Maybe I got the wrong module? Its from an 80 Monte Carlo 5.7L :?
You want a module with two blade terminals on either side. Some of the 1980 and later vehicles used electronic timing control which you do not want. You want Standard Motor Products LX301. If they insist on an application tell 'em it's for a 1976 Chevy Camaro any engine.
PostPosted: Sat Oct 17, 2009 3:20 pm
Sounds like the timing's way off; did you remove or change or touch the distributor during your installation?
PostPosted: Sat Oct 17, 2009 4:46 pm
If the distributer was not disturbed, try reversing the leads from the dist pick up to the module.
PostPosted: Mon Oct 19, 2009 2:27 pm
Thats what I thought at first. I did not remove the dist, but I hooked the mopar ign back up, and it fired up right away. Timing was perfect, abit jumpy tho :roll:
Tried that to, it was a no go. Took the module up to the local advance and it tested bad, to my surprise :wink: So I bought a new ACDelco D1906 as per the instructions. Wired it up, started right up. Its idling smoother than ever, and isnt sluggish anymore. :D
PostPosted: Thu Jan 21, 2010 9:01 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Some really great discussion going on in this thread, and maybe I missed it, but there's one big question I have before I take the HEI plunge: Where does everyone that use the relay have it mounted? Is there a mounting bracket for relays, do you make one, or does it just sit there? Can I use chewing gum?
Okay, that was three questions.
I'm planning on picking up an ECH EC23 connector and ECH AR294 relay as outlined in the new schematic on the HEI post if that helps. If any relay users wish to share their mounting secrets I'd be much obliged.
Thanks!
Chuck and the Flying Valiant
PostPosted: Sun Jan 24, 2010 5:04 pm
On mine, I have the relay and a watertight fuse holder on a small bracket that I made. It is bolted to the firewall where the ballast resister used to be. It puts it in a good spot for the ignition on wire and for the main power feed from the starter relay. No new holes to drill and it is out of the way. The new power lead then follows the factory harness around to the passenger side.
PostPosted: Mon Jan 25, 2010 5:05 am
That's a cool idea. What did you use to make the bracket?
PostPosted: Mon Jan 25, 2010 9:21 pm
It's just a piece of sheet metal about 3 inches wide by 4 inches or so tall, with two bends so it clears the body seam that sticks out above where the resister was.
PostPosted: Tue Jan 26, 2010 5:22 am
Cool! Thanks for your help. It also hit me last night that I have a junk voltage regulator I could probably convert into a discrete casing for the relay. I don't know if it'd fit or not though. I still need to go by NAPA and pick it up. :oops:
PostPosted: Sun Jan 31, 2010 6:50 pm
Good news! I got my ignition kit installed and it worked!
Better news! I found a way to solve my relay mounting problem. The guy at NAPA recommended I use ECH AR274, which comes with a built in mounting bracket and is a few bucks cheaper than ECH AR294. The only difference is it has two "87" terminals, and either works.
Still better news! After a false start, I fixed the connection to the alternator, the engine leveled out, and it ran great!
Bad news! I went out today and the battery was completely and totally dead. No click. Nothing. Um...what happened? :shock: Any ideas? Here's some pictures of my setup. I'll be shrink wrapping it as soon as I figure out what went wrong.
