| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 73 of 91 |
| Author: | slantzilla [ Mon Jan 27, 2020 10:37 am ] |
| Post subject: | Re: 1968 Valiant Ruster Racer IRWIN PA |
I'd go .0025-.003" myself. I'd also shoot for that on the rods. To open them up you can either have the crank polished or carefully sand the backs of the bearing shells. I used Scothbrite on the last set I had to diddle with. |
| Author: | Dart270 [ Mon Jan 27, 2020 11:23 am ] |
I usually shoot for 0.018 - 0.0022" on mains and rods, maybe a skosh more on the rods. Great tip on the sanding of the bearing shell backs, Dennis! I have gotten mine polished 0.0005" when I needed to... Lou |
| Author: | Dart270 [ Tue Mar 17, 2020 1:51 pm ] |
Nice work, Greg and Ava. Keep it up and have fun! Lou |
| Author: | slantzilla [ Tue Mar 17, 2020 7:40 pm ] |
Sweet! |
| Author: | slantzilla [ Tue Mar 24, 2020 8:36 pm ] |
Good stuff Greg! |
| Author: | Dart270 [ Wed Mar 25, 2020 4:00 am ] |
Impressive. I am betting your ign problems will be much attenuated or gone... Look forward to seeing the "Mad Max of the East, Beyond Slanterdome" ride again. Lou |
| Author: | Badvert65 [ Wed Mar 25, 2020 7:23 am ] |
Greg, that is too purty. It needs some duct tape somewhere. |
| Author: | drgonzo [ Wed Mar 25, 2020 7:29 am ] |
Looks uber-speedy to me. |
| Author: | Greg Ondayko [ Wed Mar 25, 2020 7:34 am ] |
Yes It has duct tape.. you just cant see it now. The thing is still pretty raunchy.. I am not sure iff you have seen it up close in person.. it's bad. Looks fast ... maybe.. goes fast....I am never confident in that until the results are proven. lots of stuff to go bad / wrong / get figured out... especially when I am the lead mechanic, driver, crew chief and wallet. Greg |
| Author: | drgonzo [ Wed Mar 25, 2020 8:57 am ] |
Quote: Yes It has duct tape.. you just cant see it now.
I resemble that remark, except for the goes fast part. All else applies. My car photographs MUCH better than it actually looks..lol.
| Author: | sixinthehead [ Wed Mar 25, 2020 10:14 am ] |
That bracket looks super heavy - a clear dearth of holes. I'm surprised that you would hang that much weight way out front like that, unless it's needed to keep the nose on the ground That's it, isn't it? Seriously though, nice work. That turd is becoming highly polished indeed |
| Author: | Greg Ondayko [ Wed Mar 25, 2020 11:43 am ] |
Quote: That bracket looks super heavy - a clear dearth of holes.
Yes its not too holey.. I didn't weigh it before the install either. It shouldn't be too heavy as it is AL. I should compare the FE Garbage to this AL one.. time to take the scale to the new shop digs. I can always add holes easy.. to make Mark and Seymour proud! I did lighten up the oil pump mount.. I didn't really document that here. It needs to be skookum as it holds the heart of the engine. Some holey finite analysis still to be had! Quote:
No you can't polish a turd.. just add holes and make it faster.. Still A turd.. wouldn't have it any other way!Greg |
| Author: | terrylittlejohn [ Thu Mar 26, 2020 3:45 am ] |
nice! your mandrel drive bolt look smaller than stock, are you using a tread adaptor? |
| Page 73 of 91 | All times are UTC-07:00 |
