It is currently Wed Oct 14, 2026 11:06 am
Post new topic  Reply to topic  [ 178 posts ]  Go to page Previous 1 … 7 8 9 10 11 12 Next
PostPosted: Sat May 22, 2010 3:57 am
any chance for dyno numbers to compare to the power pipe or PP-DC?
We started with a direct replacement with larger than stock intermediate pipe of 3" with an exit of 2 1/4" This unit was small gain over stock on dyno. Stock manifold here.
http://www.stormcomm.net/dyno.mov
This is the PowerPipe-SC Look how much quicker the torque comes in and the steady climb and fall. :D
Hope this helps with your question. This was the only one put on the dyno so far . I feel the DC and the True Flow design would be better yet Don 8)
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Sat May 22, 2010 5:38 am
so is there any chance you will have numbers for the DC and true flow in the future?
on the fence about which one...
1976 Plymouth Feather Duster
2002 Dodge Dakota 4.7l v8
 Post subject: Max torque from headers
PostPosted: Sat May 22, 2010 11:56 am
These dyno charts are very helpful. I am looking forward to the next two (DC vs True flow) as well.
Did you say you had the long hookers charted as well and the Clifford shorties? This would make a heck of a collection of dyno charts and a good Engine FAQ sticky.
I am looking for what Doc was talking about in another post earlier this week, lots of torque at lower rpms vs max HP. My engine is built for more torque so I am looking for the best exhaust to make the most torque.
Thanks,
PostPosted: Mon May 31, 2010 8:56 am
Please get a sound recording of the x+y pipe when installed.
Here you go old blue. I will have more soon, going down the road a bit, revving up!! The in car we have is all motor no exhaust sound/drone at all. :shock: When you walk out back you sure here it though!! :)
http://www.youtube.com/watch?v=6oRVNd28h-A
That was no good without pics!!
1st gear ride in TwIsTeR :D :?: How long will it take to get to 5000k :?:
http://www.youtube.com/watch?v=kq9bjeQ4fpo
My Twister Page
PostPosted: Mon May 31, 2010 9:29 am
Yes we will be testing them!! PowerPipe-DC-PF-TF :arrow:
My Twister Page
PostPosted: Mon May 31, 2010 9:57 am
Thanks for the sound bite.Sounds very good.I like the open sound.What cam are you running?
PostPosted: Mon May 31, 2010 3:15 pm
If the muffler has sufficient flow capacity a Y-pipe makes just as much power as duals with an X-pipe. It also weighs less and costs less.
Sufficient flow like a straight through muffler design? I will be testing the difference soon X plus Y and Y by itself. Yes it's a little heaver but I run two tail pipes as well. I will also save the weight and money for sure if it's not better.
My Twister Page
PostPosted: Tue Jun 01, 2010 2:50 am
The idea with both X and Y pipes is to combine pulses. I don't expect a benefit to using both together myself.
Thanks for your input on this Matt. Sometimes things just don't add up. I hope this is not one. :wink: Here we have proven X pipes work with allot of testing in their system. Many people here think like Joshua Skinner Y pipe and save the weight. We are glutton for punnishment my mother said all the time. Will it overcome the weight difference? I need to find out if this helps or not now with the :?: in my head.Feels allot better in the car, Have a good day all. :)
My Twister Page
PostPosted: Tue Jun 01, 2010 3:25 am
No problem, glad you like the sound! This was the first two chamber muffler I put together last week. I keep riding around waiting for drone. Up to 3500rpm steady running still no drone :D The air is not staying in either one of the chambers long :!: This is a good thing A. The cam is small 260-440 CompCams straight up in this motor.
My Twister Page
PostPosted: Tue Jun 01, 2010 4:27 pm
I very, very, likely will buy a set simply based on how this twister Dude has listened to members. Deep inside we all respect sweat and fairness.
Time to take that info and sum it up. Too many cooks spoil the broth. God Speed twister. GL
PostPosted: Sat Jun 05, 2010 6:20 am
Got my popcorn.
PostPosted: Sat Jun 12, 2010 2:38 am
Got my popcorn.
Sitting back and enjoying the show huh, :idea: kick your shoes off and relax rug. :)
My Twister Page
PostPosted: Sat Jun 12, 2010 2:44 am
Thank you gl/6 a little bit of this and that in the soup and it should be tasting pretty good by now. Where is the bread :?:
My Twister Page
PostPosted: Sat Jun 12, 2010 2:50 am
Spoke with Charlie on the phone :!: I am picking up the 65 Valiant with a 170 tomorrow. Headers for the early A body will be under works again this week. :shock: We will build a long and short tube set for this application. I will be making these along with the True Flow Turbo Header Design. Talk to yall soon Don :D
My Twister Page
PostPosted: Sun Jun 20, 2010 10:12 am
We picked up the 65 Valiant from Charlies last week. The header build will start this week for the early A-Bodies. The car is at the shop 225 removed and the 170 going in soon.
Flat towed er all the way to Bradenton!! :)
The 170 is a 1964 block. Thanks again Charlie! More up dates as we progress. :arrow:
My Twister Page
Users browsing this forum: Bing [Bot] and 19 guests
