It is currently Sat Nov 28, 2026 7:22 pm
Post new topic  Reply to topic  [ 1379 posts ]  Go to page Previous 1 … 85 86 87 88 89 … 92 Next
PostPosted: Fri Jan 31, 2025 4:11 am
You can see by eye that is a big cam. Can't wait to see this combo run.
PostPosted: Fri Jan 31, 2025 8:04 am
For sure. It's in the pipeline of big work to get done. The valve issues on the Grüne Hölle Engine have set me back a week or 2.
Not sure if It will be sorted by Mason Dixon this year.
I Need to Reinforce or re engineer that engine plate too, before I track it for real.
We shall see!
PostPosted: Fri Jan 31, 2025 8:18 am
You can do it! 4 months! :D :D Anxious to see it goooooo! :mrgreen:
PostPosted: Fri Jan 31, 2025 10:44 am
Yep for sure,
Maybe some clanspeople can come over and help a bit...
I know know guys are not busy with big ideas or building houses in the forest or taking care of 23 cats or anything. :mrgreen:
 Post subject: 4/5/26
PostPosted: Sun Apr 05, 2026 8:28 am
It seems life and other things got in the way.
Ruster did nothing in 2025 except sit in the garage and some Halloween duty.
A few weeks ago I began to dis-assemble the front clip, drain fluids etc.
I got the new converter installed. Now I have to put the new cam in as well as replace the bent engine plate.
I am going to tidy up some electrical things as well as engineer a fore - aft limiter system for the engine so the new block plate does not bend with the hit on the trans brake launch sequence.
I might have found my electrical cutout as well. In Sept 2024 when I was racing at Knoxville, the Car developed some sort of electrical cut which I believe was a loose connection on my oil pressure warning cutout switch. This loose connection would have cut voltage/ current to the megasquirt and in doing so caused a misfire.
Tomorrow I hope to get some time on the cam and block plate installed.
Engine Out, Getting the Gumby plate off of there soon.
I had a light Converter in the car, but the new one weighs a bit more :-( But if the car is faster, then I am okay with that.
PostPosted: Sun Apr 05, 2026 1:49 pm
Looks like a nice start, Greg. Always fun to see Ruster out there goin' down the track and freakin' people out...
PostPosted: Sun Apr 05, 2026 4:18 pm
Good stuff Greg! Electrical gremlins suck.
PostPosted: Sun Apr 05, 2026 4:49 pm
Yep,especially when they are caused by the idiot that engineered and drives the monstrosity.
:D :D
 Post subject: 4/6/26
PostPosted: Mon Apr 06, 2026 3:36 pm
Made a bit of progress today.
Got the engine plate, all of the front drive bits and accessories removed. I also got the timing cover off along with the damper.
Next time I should be able to pull the head and remove the original cam .
PostPosted: Tue Apr 07, 2026 9:33 am
Nice, Greg. FWIW, I usually leave the head on when I swap cams.
PostPosted: Tue Apr 07, 2026 9:45 am
That is why I like the drool tube heads! :D I can get the lifters out!
PostPosted: Tue Apr 07, 2026 7:05 pm
Yes typically I would do that but how to check the piston to valve clearance with the head on is my dillemma.
PostPosted: Tue Apr 07, 2026 7:39 pm
Just swap out one exhaust valve spring with a checking spring. Spin her over and check it around your TDC position. That is usually where our problem is. If you have plenty of room I would opnly do one. Now if it was close....... maybe I check more?? If you drop the valve, oh well, you wanted to pull the head anyway! :D :D Good luck Greg!
PostPosted: Tue Apr 07, 2026 7:46 pm
Great. Thanks. Now I need to get a checking sping. Dont have one of those.
PostPosted: Wed Apr 08, 2026 8:28 am
That might work with a lawnmower cam, but real cams can get cozy on the intake side after TDC...... :shock:
