| 1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?t=36132 |
Page 90 of 91 |
| Author: | Greg Ondayko [ Mon May 04, 2026 8:17 am ] |
| Post subject: | Re: 1968 Valiant Ruster Racer IRWIN PA |
Greg, I see you have Allen adjusters on your Goodman rockers.
Hi Stan, I don't remember for sure; they likely came with the rockers, but I could be wrong. I have a few sets of these rocker arms.Do you remember where you got those? Either way, buy this style of ball rocker screws from Smith Brothers Pushrods. Measure the length of the current parts you have before ordering. If you poke around on their website, you can find sets of rocker screws with jam nuts, too. Greg |
| Author: | hyper_pak [ Mon May 04, 2026 1:10 pm ] |
OK, Mine are flat screwdriver style. I don't like that. I will check out smiths |
| Author: | Greg Ondayko [ Mon May 04, 2026 2:34 pm ] |
Agreed, I remember having flat screws somewhere, too. They are harder to be delicate with for fine adjustments, and the tool often slips out of the slot. I don't like that. I will check out smiths Greg |
| Author: | Greg Ondayko [ Sun May 10, 2026 4:38 am ] |
| Post subject: | 5/8/26 |
5/8/26: I got back to the shop for an hour or 2 of work after a concert here at school. I was working on some more fiddly bits, connecting the maze of oil, pan evac, and coolant lines. Many of the Heim Joint/rod end parts have arrived to begin preliminary measure-up / fab up. I still need to install the intake/exhaust, revise the fuel line routing, and get the torque converter bolted to the flexplate with a liberal application of Loctite 271 red schmoo! Lots to do, but it is possible! Greg |
| Author: | Dart270 [ Mon May 11, 2026 7:50 am ] |
RUSTAAAHHHHHH!!! |
| Author: | slantzilla [ Tue May 12, 2026 8:04 pm ] |
Nice work Greg! |
| Author: | Dart270 [ Wed May 13, 2026 6:50 am ] |
Very clever and thorough work, Greg! Lou |
| Author: | Greg Ondayko [ Wed May 13, 2026 8:11 am ] |
Thanks, hopefully no more broken trans mounts or bent engine plates. Time and time slips will tell if I made good decisions or not! Greg |
| Author: | Dart270 [ Sun Jun 21, 2026 11:04 am ] |
Very cool! Glad to hear it is buttoned up and new and improved. Interested to hear testing results... Lou |
| Author: | Greg Ondayko [ Sun Jun 21, 2026 11:29 am ] |
I solved the dumb oil leak too with some "The Right Stuff" on the outside seam. Might get down there today for some more work. |
| Page 90 of 91 | All times are UTC-07:00 |
