It is currently Sat Nov 28, 2026 10:39 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Thu Dec 09, 2004 8:55 pm
Great car, love the air grabber setup. Nice work all around. Looks like your top slider bracket for the alternator required no mod, but I can't see what mod you might've made to the stock lower bracket. Care to elaborate?
PostPosted: Thu Dec 09, 2004 9:06 pm
There was slightly less space between the ears, so I had to grind maybe .100" off the lower cast bracket (been a long time ago, don't remember exactly). I think it was form the backside, but whichever it was, I checked to make sure the belt alignment would be dead-on. The pulley came from the local alternator shop, the counterbore was too shallow, fixed that on my lathe, I think you can get a bolt-on if you find the right year minivan or similar. I inserted a 10 cent nylon sleeve from the hardware store in the upper adjustment hole to take up slack between it and the 5/16" NC bolt/nut, but this was purely optional and to make for a good fit with no slop. The field wires on the ND were a post/nut arrangement with molded electrical connection on the donor minivan, I cut the spade ends off some old Chrysler alt brushes and made some nice trick "adapters" by securing them to the ND with the holes in them and bent them 90 deg for a nice, clean installation... Did ya get all that?? ;)
D/W
If it ain't broke, fix it!
PostPosted: Thu Dec 09, 2004 9:09 pm
Yep, makes perfect sense; I intend to do the same swap on my '62 Lancer next time I visit it. I'll recondition the alternator off my '89 D100 (which is a Dippynonsense already equipped with the right pulley) and put that in the '62.
Thanks for the specs!
DS
PostPosted: Thu Dec 09, 2004 9:13 pm
Cool. My '88 truck (318) has a "big" ole Bosch alternator... Never seen the ND on a truck of that vintage, but then there's lots I haven't seen ;)
D/W
PostPosted: Thu Dec 09, 2004 9:19 pm
'87 was when all the Mopar rotating electrics began to change. That was the year the Chrysler 40/90 and 50/120 alternators (w/big black plastic cover on the rear housing) were introduced. The Bosch 40/90 and 50/120 followed in '88, and the Nippondenso 40/90 and 50/120 in '89. Also in '89 came the Nippondenso mini starter (which I removed from my truck 'cause it sounded like a Subaru when cranked. Currently has a Chrysler 3/1-wound starter that works fine, but I'm going to experiment with the Bosch starter next time I'm under the truck.)
PostPosted: Thu Dec 09, 2004 9:28 pm
...have you worked for Chrysler? You know too much about emission controls and other data not to have! :lol:
D/W
PostPosted: Thu Dec 09, 2004 9:43 pm
Nope, never worked for 'em...
PostPosted: Fri Dec 10, 2004 3:42 am
Check out the www.powermastermotorsports.com alternators. Those usually have higher output on both ends.
By output are you referring to voltage? A problem I had with the 120A alt in my truck was that it would only put out 12V at idle, and wouldn't put out a full 14V under 1200RPM. Above 1200RPM it was great though. I could have everything on full and no voltage drop. If I could get a high output alt that could put out a full 14V at idle, I'd be all over it.
My 120A's voltage regulator just took a dump actually, so I'm putting a stock 80A (factory reman from the local Toyota dealer) Nippondenso alt in.
PostPosted: Fri Dec 10, 2004 9:12 am
No, in the context of a charging system discussion, "output" means current in Amps.
PostPosted: Fri Dec 10, 2004 9:52 am
Dang. I know the amperage output at idle was good with my 120A alt, but the voltage always sucked. I'd like to find a high output alt that can still put out 14V at idle like the stock 80A units...
PostPosted: Fri Dec 10, 2004 9:53 am
Well, what's your whole system look like? You're talking about internal regulators, so these are definitely not alternators from Chrysler products.
PostPosted: Fri Dec 10, 2004 10:01 am
Well, what's your whole system look like? You're talking about internal regulators, so these are definitely not alternators from Chrysler products...[/img]
It's an '88 Toyota Land Cruiser. Bit different from anything with a slant, but there are enough similarities that I can compare the engine to the 225 in my girl's Dart on alot of aspects :P
The charging system has always been a big deal with me, with my higher draw headlights, and plans for driving lights and other electrical equipment. There's also alot of high draw stuff my girl and I plan on putting in her Dart, once we get the opportunity to really dive into it.
PostPosted: Fri Dec 10, 2004 10:19 am
SSD--you say introduced, so i assume these alts were not on all vehicles? (As my '87 came with what I assume was an 'old' style 78 amp alt, no plastic cover on the back?)
Jopapa-
If you're up to a little bracket fabrication, grab an alt off any newer car. My alt is from a '96 intrepid (Nippondenso?), and it holds 14.2 volts at a 500 rpm idle (in gear) with absolutely everything I can possibly turn on, on (headlights, hazards, stereo w/ amplifier, heater, wipers). I have not been able to make this alt show below 14.2 volts, ever. Without being fully loaded, it holds 14.4 volts at that 500 rpm idle (in gear). The only somewhat strange issue I have found is that on cold starts, for about the first 1 or 2 minutes, my voltmeter shows 14.6 volts. After those initial 1-2 minutes, it creeps back down to 14.4 volts and stays. (maybe VR 'warming up?)
I simply hooked the field wires up to the factory regulator. Voila, no more idle charging issues. The 6 gage output wire I have running from alt to battery probably isn't hurting either. ;)
The 100 amp factory alternator I was running before doesn't hold a candle to the intrepid alt.
-S/6
PostPosted: Fri Dec 10, 2004 10:22 am
Yep, "introduced", phased in, etc. Many '87s still came with the Chrysler squareback alternator, and so did some '88s.
PostPosted: Fri Dec 10, 2004 11:04 am
Well I'm intrigued. There are three other wire connections on my alt that I'd have to figure out how to work around, but this has my attention. What's the amperage on the Intrepid alt?
