It is currently Sat Nov 28, 2026 8:33 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Dec 08, 2004 8:31 pm
I just replaced my altetor and my lights will still dim when i do anything else, like blinkers or wipers. so whats goin on
PostPosted: Wed Dec 08, 2004 9:30 pm
That's because there are a couple of things fighting against you:
1)an alternator with bad idle charging characteristics
2)30 year old wiring
3)all power goes through the ammeter
Basic things that might help this would be making sure your idle is set right, you have a good voltage regulator, and your wiring is clean without badly done backyard wiring repairs. If all this checks out then you're pretty much good. I've actually managed to fix this problem myself, but I've done a lot of re-working on my wiring. If you feel that something is out of the ordinary it might be beneficial to describe your exact problem, such as: are your lights dimming while not at idle(not normal), do they only dim somtimes, did they ever not dim with increased load, etc.
-Shivadart
PostPosted: Wed Dec 08, 2004 10:01 pm
I second all of the above comments. One more thing - be sure that you are running the smallest diameter alternator pulley possible.
D/W
If it ain't broke, fix it!
PostPosted: Thu Dec 09, 2004 8:36 am
Something that doesn't cost you a thing except some time is to make sure your headlight, engine, etc grounds are actually making a good ground. Also you might check the firewall junction box to make sure there's no corrosion at the terminals
PostPosted: Thu Dec 09, 2004 1:28 pm
"Remanufactured" alternators that you buy at the parts store are garbage. Many of them will cause exactly this problem.
PostPosted: Thu Dec 09, 2004 4:49 pm
I agree that some are, but I've also lucked up and gotten some good ones. I always keep all the guts (the stuff that's still good, at least) before I give 'em back a core. That way, I can usually fix or piece together another good one with the diodes and brushes and such that I keep. That's the problem with trying to rebuild your own - you'd end up paying three or four times what a sleazy reman costs just to buy the diodes, bearings, brushes etc.
I don't think there's ANY excuse for getting a cheesey low-amp/difficult to service heart-back style anymore, unless you are going for a "correct" restoration - The square-backs can be obtained in much better output versions and the diodes are easy to replace. Converting them to a one-wire field (if necessary) is as simple as removing one insulating washer and replacing it with a metal one to ground one field connection.
D/W
PostPosted: Thu Dec 09, 2004 5:14 pm
I don't take my chances of parts store "reman" garbage any more -- the odds of getting a good one are way too poor, and as a whole they're far too unreliable.
While the squarebacks are easier to service, there's nothing wrong with the roundback alternators, and the focus on "better output" (amperage numbers) is one of the main causes of the dims-at-idle complaint, for the higher-output alternators tend to have poorer low-RPM output.
PostPosted: Thu Dec 09, 2004 5:46 pm
Check out the www.powermastermotorsports.com alternators. Those usually have higher output on both ends.
PostPosted: Thu Dec 09, 2004 5:52 pm
Er...no, thanks. Too much crap outta those people, for too much money.
I patronize my local auto electrical shop. They'll rebuild whatever I bring them, to my specs, and the results are better, more durable, and less expensive.
PostPosted: Thu Dec 09, 2004 5:59 pm
I called a local place that specializes in alternators, mainly for diesel trucks. He told me he can rebuild it to have higher output but it will sacrafice it at low rpm. So I decided not to that, because he also said I would have to get a different, more expensive regulator.
Powermaster makes an 80a (not sure about output specs) direct bolt-on for for a slant for $100, may of been less.
Yes they are deffinately more expensive but I haven't heard anyone say anything bad about them.
PostPosted: Thu Dec 09, 2004 6:21 pm
...and the focus on "better output" (amperage numbers) is one of the main causes of the dims-at-idle complaint, for the higher-output alternators tend to have poorer low-RPM output.
On what do you base this Dan? That's never been my experience, but maybe it's a fluke...
D/W
P. S. - I have been very pleased with the Nippon-Denso 90 amp unit that I fitted to my '70 Duster. Idle output is great, no dim headlights, and I still haven't upgraded the cheesy 35 year old wiring (but plan to).
PostPosted: Thu Dec 09, 2004 8:09 pm
It's due to the way the stators are wound to get higher output. Heavier-gauge wire allows higher output, but you have to spin the alternator faster to induce significant current in the heavier wires. You can compensate to some degree with a smaller drive pulley, but then the load on the engine is greater.
The later-model alternators (whether made by Nippondenso, Bosch or Chrysler) are indeed nicer all across the range. What bracket setup did you use to install the Nippondenso on your '70?
PostPosted: Thu Dec 09, 2004 8:26 pm
Stock '70 alt brackets with minor modifications... Reference pics in Slixer's Gallery and some related posts somewhere...
D/W
PostPosted: Thu Dec 09, 2004 8:36 pm
Slixer's gallery...???
PostPosted: Thu Dec 09, 2004 8:42 pm
http://www.slantsix.org/forum/viewforum.php?f=12
Look for the pics of my Duster there.
D/W
