Getting the wheels and tires right. ???
https://slantsix.org/forum/viewtopic.php?t=30564
Page 2 of 2
Author:  Joshie225 [ Mon Aug 18, 2008 6:23 pm ]
Cool steelies. What are they from? Did you need a spacer in the back? I really wish I could find a rear axle 2" wider than stock so I won't have to use spacers with my wheels.
Author:  steponmebbbboom [ Mon Aug 18, 2008 7:00 pm ]
seconded, please tell us where you got the steelies. theyd look great with a set of UFOs.
Author:  75customdart [ Mon Aug 18, 2008 7:07 pm ]
The wheels came from a chrysler 300. I had to run a 7/16 spacer in the back to clear the leaf springs. I'll grab some better pictures when i get home.
Author:  SlantSixDan [ Mon Aug 18, 2008 10:15 pm ]
I hope you are going to tell us you only install those wheels for show and don't actually drive on them. Spacers are very, very dangerous.
Author:  75customdart [ Tue Aug 19, 2008 3:37 am ]
I agree spacers are dangerious. Exspecialy ones you see on ebay, summit racing and jegs, with a non-hubcentric, universal, sloppy fit. I had a one off set of spacers milled by a buddy, that are hubcentric for a perfect fit. I also install longer studs and retorque my wheels often. And dan the spacers are only a temporary thing I plan on adding the lenght needed while doing an axle swap. Im taking the car off the road for the fall and winter in about a week after i finish moving. Axle, transmission and engine swap are starting in the fall. A very cleanly installed sterio system is in the process at the moment
Author:  Dart270 [ Tue Aug 19, 2008 6:11 am ]
Best idea I've heard is the 205/60-15s on your 15X5.5s. You will see nice handling gains and mileage will not suffer and may get better.
Author:  rebel_cat68 [ Tue Aug 19, 2008 7:43 am ]
I bought from US Wheel the "series 26 chrome blade", 15x7" wheels (bolt circle 5x4.5).
Part #26-5712, backspace 3.75" for the back,
and part #26-5712P, backspace 4.5" for the front,
so that the axlewidth would be a bit more equal.
They weigh a bit but I'm satisfied. Put 215/65-15 tires all-around.
Author:  ValiantOne [ Tue Aug 19, 2008 8:36 am ]
Lou this is what I am leaning towards. just got a set of dog dish caps that would look great on the black steelies.
C
Page 2 of 2 All times are UTC-07:00
