It is currently Sat Jun 20, 2026 6:09 pm
PostPosted: Fri Aug 15, 2008 2:13 pm
Hey All,
I am getting ready to purchase some tires for my \6 4d 73 Dart driver. I want to do this right the first time.
Right now the car has 195/75/14 's on stock steel lbp wheels. I also have a set of 15" lbp wheels at my disposal
I have not figured out what gear is in the rear yet (l'll do that this weekend) but I assume it is a highway gear.
I am trying to find out what the ideal tire height will be for a daily driver with fuel mileage being the goal. I was thinking I could use a lower profile tire with the 15" rims vs. the 14's and get a bit of handling back to boot.
I will update this post when I figure out the rear end ratio. For now, does anyone have a combo they have had good luck with. Or maybe a rule of thumb for figuring out the best height for my purposes?
Thanks,
CE
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
PostPosted: Fri Aug 15, 2008 2:37 pm
For mileage you want the largest total diameter tire and the skinniest tire width that will safely fit.
PostPosted: Fri Aug 15, 2008 2:55 pm
How wide are your 14" wheels?
"Tallest tires possible for best possible mileage" is not necessarily correct. If you effectively undergear the car by making the tires too tall, you'll have your foot well into the carburetor's power valve all the time just trying to make the car get out of its own way, and that uses up a lot of gasoline. The optimal tire diameter depends not only on rear axle ratio and engine/transmission configuration, but also whether you use the car mostly in town, mostly on the freeway (and if so at what cruise speed) or an even mix of both.
PostPosted: Sat Aug 16, 2008 4:04 am
Exactly. A friend of mine got better mileage after switching to a steeper gear (went from a 3:90 something to a 4:10) because his foot wasn't down hard trying to keep his speed up.
today I will get out and get the rear ratio, wheel width and so forth
Thanks,
 Post subject: optimal tire size
PostPosted: Sat Aug 16, 2008 6:31 am
go to (www.tirerack.com) I think that is the correct site. They have an upgrade garage. It will assist you in determining the 15" tire size that matches your factory 14"--- It also has the formula -- so you can plug in other sizes.
Lawrence
PostPosted: Sun Aug 17, 2008 7:45 am
Ok, I pulled the diff cover while changing the gear oil yesterday. Here are my specs.
-Holley 1 bbl carb (engine is getting a super six upgrade in the near future)
-Stock 73, 904 trans
-2:76 rear gears
The rims I have to choose from are
-14 X 5.5 LBP ralleys
-15 X 5.5 LBP steelies
about 50/50 highway vs. city driving. I am looking for mileage in this car. So what would be my ideal tire height?
Thanks for any info!!!!
CE
PostPosted: Sun Aug 17, 2008 9:35 am
Well, 205/65R15 is the same 25.5" diameter as the 195/75R14. Trading an inch of sidewall for an inch of wheel improves steering response and the lower profile usually has a greater tread width. This is the Plus Size Concept. Plus one is nice, but I'm about to do +3 on my Valiant with 255/40R17 on the back and 235/35R17 on the front.
PostPosted: Sun Aug 17, 2008 9:56 am
I would buy a set of 205/70R14 BFGoodrich Radial T/A tires, put 'em on the 14" x 5½" wheels, and be happy. I'd probably be happier with more gear than 2.76 — I really like a 3.2 rear axle with 205/70R14 tires — but that can come along down the road sometime if you decide you want it.
PostPosted: Sun Aug 17, 2008 12:46 pm
Dan's recommendation is a good one, particularly with your 14" Rallye wheels. Reasonably modern tires and good looks!
I went with 205-60R15's on 15X7's, as a Plus Two from the 185-80R13's that my car had when I got it. This is a good size for my '64 with 2.94 gears, essentially duplicating the old tire diameter and keeping the speedometer reasonable accurate.
Here's a TIRE SIZE CALCULATOR so you can compare sizes.
PostPosted: Sun Aug 17, 2008 7:15 pm
Hey, those are the exact tires I want, though no place around here sells them. :(
I have 205/75R14s on the front and rear, mounted on 14" Cragar SS rims, and I think they are just fine, but a little big. I have normal acceleration and handeling, although I do get the accasional "scrape" when im backing out of the driveway.
14" Cragar SS wheels
PostPosted: Mon Aug 18, 2008 5:29 pm
Hey joshie im all in on your idea of 17". I've be thinking, dreamin, and test fitting for about the last 5 months on which way to go. This is what i came up with. 225-45r17 front 245-45r17 rear the steering responce and control gained is amazing. Not to mention the looks i get.
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
PostPosted: Mon Aug 18, 2008 5:38 pm
Get those blue phony-zeenon diamond-crystal toy headlites off the car now, please, before you cause a crash and lose your beautiful Dart.
PostPosted: Mon Aug 18, 2008 5:41 pm
Dont worry dan they are a show only light never to be lit on the road. Im saving up for a set from you some time in the future. Im getting tired of putting them in and taking them out after shows.
PostPosted: Mon Aug 18, 2008 5:59 pm
OK, cool. I never require that anyone buy any lights from me — I wasn't badgering you to buy lights from me here — it's just that those lights like you have in there are so unsafe that I have to squawk when I see 'em in a car. Glad to read you don't actually use them.
PostPosted: Mon Aug 18, 2008 6:12 pm
I admire your knowledge of lighting and will get in contact with you on a later note about the light. As i was putting the picture onto my post I thought to myself " I wonder how long till dan will comment on my light" and not even five minutes later you noticed.
