| turbos https://slantsix.org/forum/viewtopic.php?t=3063 |
Page 2 of 2 |
| Author: | Bob D [ Sun Jan 06, 2002 7:00 pm ] |
| Post subject: | Re: TURBO and VIDEO |
: wheres a good place to look for a 3.8 turbo? i : looked all over the internet for a 3.8 and : was unsuccsesful in finding one. MadMax Actually you were responding to my (Bob D) post here. I know that this can get a little confusing sometimes. For a used 3.8L Buick turbo check out <A HREF="http://www.Gnttype.org/trader/traderads ... ds.html</A>. I saw a couple there recently. Bob D BBobbias@aol.com |
| Author: | Bob D [ Sun Jan 06, 2002 7:06 pm ] |
| Post subject: | Re: MSD 6 BTW |
: sure, how do i do it?
Hopefully Doug will chime in here and tell us. I think the easiest way is to just e-mail the pictures to him. Bob D BBobbias@aol.com |
| Author: | elam [ Sun Jan 06, 2002 7:17 pm ] |
: wheres a good place to look for a 3.8 turbo? i : looked all over the internet for a 3.8 and : was unsuccsesful in finding one. MadMax I just bought a garret turbo off a turbo coupe at the junk yard complete for $25. The man there is a good friend of mine. He has played with turbos before took me over to a few Mercures they had the same garret turbo's on the same 2300 engine as the turbo coupe. Seams like a good sourse to me they are plentiful. melam@nxs.net |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Jan 06, 2002 8:45 pm ] |
| Post subject: | Re: PICs of turbos *PIC* |
: Here are some questions for anyone who knows : anything about turbochargers. Im putting one : on my slant6. Madmax, To post Picture(s) on the message board, the image needs to be "up-loaded" onto the internet. (or it could already be posted at some website) Once you have the on-line image, copy / paste the URL address into the Optional Image URL post box below the message field. (It has to be the full "http://www....jpg" address) If you don't have the PICs on the web, I can work with you to get them uploaded. The big trick with web site PICs is to crop them down and compress the size so they download fast. DD
| Author: | andrew [ Mon Jan 07, 2002 5:18 pm ] |
go to ebay motors and look under turbocharger. There are some nice turbos there!!! andrew wagner Quote:
: wheres a good place to look for a 3.8 turbo? i : looked all over the internet for a 3.8 and : was unsuccsesful in finding one. MadMax |
| Author: | andrew [ Mon Jan 07, 2002 5:29 pm ] |
Yes it was from switching from the small turbo too the bigger one. Don't be ashamed It is a learning experence doing something costom. Just learn from the mistakes and move on. I had to make my headers 3 times before I got what I wanted. As for the antifreezes do you mean for the cooling of the turbo? The small .48 a/r turbo got me to 15.12 @ 89 mph which I was very happy with, but I just wanted to see how far I can take the /6. One more thing the turbos from the 2.2 and the 2.5 engines are basicly the same. andrew wagner Quote:
: would it make any difference if it came from a : 2.5? The thunderbirds are only a 2.3 4 : cylinder, right? Im half ashamed to admit : but I didnt take a close look at what the : LeBeron had in it.When you say you gained in : th 1/4 mile, was that verses a small turbo : or verses a stock SL6? Also, where did you : pick up your supply(pressure) line for the : antifreeze? Thanks for offering to help. : You'll probably be hearing alot from me.By : the way the car is a 1968 Barracuda Coupe. : Ill try to e-mail some pictures of what i : have done to your site. Yes i plan to : intercool it, Im trying to figure out how to : place the hoses and tubing so I dont have to : cut the radiator support. : : MadMax |
| Author: | Dave Clement [ Tue Jan 08, 2002 6:05 am ] |
: Yes it was from switching from the small turbo : too the bigger one. Don't be ashamed It is a : learning experence doing something costom. : Just learn from the mistakes and move on. I : had to make my headers 3 times before I got : what I wanted. As for the antifreezes do you : mean for the cooling of the turbo? The small : .48 a/r turbo got me to 15.12 @ 89 mph which : I was very happy with, but I just wanted to : see how far I can take the /6. One more : thing the turbos from the 2.2 and the 2.5 : engines are basicly the same. CC used four distinctly different turbos and two different manufactures over the life span of the 2.2 / 2.5 family of turbo motors. The best choice for a slant 6 (not that it would better than a 3.8 GM turbo) would be the Garrett Unit out of an 89 and newer Inter-Cooled Turbo car as well as non intercooled 2.5 "Hi-Torque" motors . This unit had a bigger turbine housing with a 2 1/2" outlet. The worset would be the Mitsubishi turbo out of a 87-88 Inter-cooled turbo car, this was also used in some 87-92 non intercooled cars. Even in the 2.2 /2.5 engine the mitsubishi turbo is restrictive and will not provide much more than 18psi boost. The early turbo cars had Garrett's with a small turbine housing and 90 VNT cars have a variable nozzle turbo (ie; no waste gate). The big outlet garrett unit will support 300+ HP and will get a 3000lbs Daytona into the 12's or a 2400 lbs Omni into the 11's. All of the garrett turbos are T03's. I have run a best of 15.2 in my basically stock 89 Dyatona Shelby and with a little fine tuning similar cars are running high' 14's. This is at 14psi boost. Bumping the boost to 18psi gets these cars into the 13's. Hot-Rod 6 dave.clement@motorola.com |
| Author: | Richard [ Sun Jan 13, 2002 11:02 pm ] |
| Post subject: | Re: turbos |
what about two 1.8 turbos? Run the slant with the offy dual carb intake , two dutra exhausts, and two one.eights, like off an import (colt turbo for you purests) You could run the slant liek two individual balanced motors front 3 and rear 3. Good power pulses for the blower, Less lag, less airflow per turbo, more booste, more buted cranks = GOOD TIMES!!!!: We need to get madmax hooked-up with Andrew! Quote:
: : Check out his set-up at: : <A HREF="http://home.earthlink.net/~mrdartgt/ind ... ex.html</A> : : Andrew is a lucky guy having access to all that : sheetmetal fab. equipment. As he has shown : us, now it's a "what can you think of : next" (and have time for) development : effort. : DD Richard-c@e-d-a.com |
| Page 2 of 2 | All times are UTC-07:00 |
