| will a 265 Hemi Cam work in a Slant 6? https://slantsix.org/forum/viewtopic.php?t=32762 |
Page 2 of 2 |
| Author: | Joshie225 [ Fri Dec 26, 2008 8:48 am ] |
| Post subject: | Re: will a 265 Hemi Cam work in a Slant 6? |
Quote: E49 cam spec was 232/232 deg. @ 50, .477"/.477" lift at 110 l/c, or at least that's the specs of the 'reproduction' E49 cams we grind.
That's a hydraulic profile correct?
| Author: | OzHemi [ Fri Dec 26, 2008 5:58 pm ] |
Yes, the Hemi-6 is hydraulic... |
| Author: | Joshie225 [ Fri Dec 26, 2008 7:12 pm ] |
The reason I asked is that the advertised duration for hydraulic and mechanical cams will be different to achieve the same valve opening and closing points. Typically you need about 8° more duration with a mechanical cam to account for the lash. |
| Author: | nqkjw [ Tue Jan 27, 2009 8:02 am ] |
E49 cam specs-hydraulic IO 40 BT IC 88 AB Adv Dur 308 deg EO 80 BB EC 48 AT Adv Dur 308 deg Overlap 88 deg Valve lift 0.480" with std 1.71 rocker ratio Hope this helps |
| Page 2 of 2 | All times are UTC-07:00 |
