It is currently Mon Jun 22, 2026 4:16 pm
PostPosted: Fri Dec 12, 2008 4:04 pm
I have heard the 265 HEMI E49 spec cam and it is beautiful! Can you use the 265 camshafts in the 225? If not, I think I would want a cam ground to these specs
SPECS : ** 256/246 DEG @ 50 ** .564/.545 LIFT ** 4000 - 7000 RPM
or is there a camshaft like this already available for the slant?
PostPosted: Fri Dec 12, 2008 4:18 pm
The cams do not interchange between the Hemi and the SL6.
You can have a cam grinder do a custom cam grind, using the specs listed.
Oh... look at that, it's an RDP cam design. :P :o
PostPosted: Fri Dec 12, 2008 4:27 pm
That's a lot of duration! I'd probably run about an 11:1 compression ratio, some pretty steep gears (4.10 or more) and a 3500+ stall torque converter.
If you don't want to get that crazy with the engine I'd go for about 235°/225° duration at .050" tappet rise and about 10:1 compression.
 Post subject: duration
PostPosted: Fri Dec 12, 2008 6:24 pm
and it sounds like a v8 idling, its just so lopey, like its on steroids!
I thought it would be good for my blower set up with stock compression
 Post subject: Rdp?
PostPosted: Fri Dec 12, 2008 6:29 pm
what is it meant by reverse dual pattern? I am new to camshaft talk lol
PostPosted: Fri Dec 12, 2008 6:41 pm
Reverse dual pattern is the term for a cam with longer intake duration than exhaust.
 Post subject: thanx
PostPosted: Fri Dec 12, 2008 7:15 pm
so this would be a good cam for my blower setup, with roughly 8psi on stock compression?
PostPosted: Fri Dec 12, 2008 7:20 pm
No, too much duration and overlap.
PostPosted: Fri Dec 12, 2008 7:30 pm
well I might save the blower for something else then, because I would like to run a cam like that one, was thinking of using 6 mikuni vm style carbs, its been in my head for a few years
PostPosted: Fri Dec 12, 2008 7:56 pm
I have a Clifford in my junk that is pretty close to that. :shock:
PostPosted: Fri Dec 12, 2008 8:56 pm
6 Pack Dart
See this thread
http://slantsix.org/forum/viewtopic.php?t=30802
PostPosted: Sat Dec 13, 2008 4:34 pm
BTW...that is MUCH larger cam then the E49 used...they where around .488 lift from memory.
I ran a .505 lift, 305 duration in my 265 and that was not too bad.
 Post subject: yes sorry
PostPosted: Sat Dec 13, 2008 5:24 pm
yes that cam is not the E49 spec, It's an aftermarket one from PENTSTAR PERFORMANCE for the 265, my mix up
PostPosted: Sun Dec 14, 2008 4:00 am
That cam is close to my '64 Dart cam (250 @ 0.050, 0.510"). I run about 10.5:1 comp and it works fine down to 2500 RPM and up to 6000. Drive it everywhere. The 225 can handle a lot of cam. Looks like that would work very well with 11:1, but not with a blower....
PostPosted: Fri Dec 26, 2008 8:32 am
E49 cam spec was 232/232 deg. @ 50, .477"/.477" lift at 110 l/c, or at least that's the specs of the 'reproduction' E49 cams we grind.
SV-1 "RoadToad"
VC/AP5 "Plymouth TurboJet" nostalgia dragster ute project
AP5 Regal sedan parts car (late Aus spec - RHD wipers)
AP5 sedan parts car (early USA spec - LHD wipers)
Kawasaki GPZ750
(and no more Fiats - ever!)
