It is currently Wed Dec 31, 2025 6:26 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Aug 24, 2010 7:51 pm
i agree with doc. just keep a bottle around with some gas in it. thats what i do.
PostPosted: Wed Aug 25, 2010 12:36 am
Then I think I'll just have to live with it.
I'll try to unscrew the fuel line to the carb to see if the needle is leaking, but other than that, that's it.
Thanks,
Antoon
suffering from severe moparitis
PostPosted: Wed Aug 25, 2010 5:42 am
I don’t recall having such a problem with dry starts back in the days of atmospherically vented carburetors if they are working properly. Than again it doesn’t get too hot around Maine for days on end.
Perhaps all of these troublesome carburetors need a freshening up with a rebuild. My 82 LeBaron is carburetored, granted it has a vapor return system, but that engine always fires right up at any temperature after weeks or months of not running.
PostPosted: Wed Aug 25, 2010 8:46 am
Like Doc says, having the exhaust manifold bolted right to the intake causes the the fuel to boil and vaporize during heat soak. To eliminate that Chrysler used a aluminum heat deflector blanket to minimize the heat transfer. I have seen that on several two barrel Super Six set ups on trucks.
As an experiment I have found that even making a much smaller and simpler $10.00 .090 thick aluminum deflector helps a lot to minimize the effect. Also after switching over to an electric fan the problem significantly reduced to where my engine will start any time with one pump. I have my fan wired to where it can come on as many times as it needs to during heat soak. So the carb never gets too hot to touch. In fact the aluminum also wicks away heat as well as deflects it. Between the SL6Dan's fuel line mod, heat deflector and electric fan, the problem has gone away. However, some carbs vent more than others. My 1920 has the fuel bowl vapor return line system. That pollution control system is worth keeping on your vehicles.......:D
Click on the red link below my name to view pictures of the set up.
PostPosted: Wed Aug 25, 2010 4:44 pm
There is a picture of the factory original heat shield from a parts catalog or manual in one of the links in one of my posts here in this thread.
Olaf.
Aspenized
PostPosted: Wed Aug 25, 2010 4:54 pm
Olaf.
Where?
What thread?
PostPosted: Wed Aug 25, 2010 6:33 pm
This, the one you're in right now, first link in my second post.
Olaf
Aspenized
PostPosted: Sat Aug 28, 2010 4:29 pm
Make sure the electric pump will let the gas flow thru it when it's off. I used one of those cheap vibrating ones that look like a cube.
Brand? Vendor?
Ken
PostPosted: Sat Aug 28, 2010 7:28 pm
Not sure if it's the exact one (as there are several manufacturers)
At the time I got the cheapest one that was on sale
Something like this
http://www.jcwhitney.com/universal-soli ... ilterid=j1
Lowest pressure (1-3psi)
PostPosted: Sun Aug 29, 2010 7:55 am
I understand why heat soke could cause such a problem, but wouldn't that mean that the carb will dry out immediately, or at least after one day? Usually an engine is back to outside temperature after a few hours. But since my car starts perfect after one or even two days. After three days it starts ok, just needs a little more cranking, but after a week I'm cranking the hell out of it.
A little offtopic, but my three cilinder 1988 suzuki alto, which is also carburated even starts fine after sitting for a month, just touch the key and it goes.
I'll try to cap of the bowl vent after a long drive, and see what happens.
Antoon
PostPosted: Sun Aug 29, 2010 8:49 am
Antoon,
You need a new needle and seat to keep the fuel from draining back and a good float that isn't fuel soaked and sunk. My fuel pressure gauge shows between 4 and 9 pounds after shut off and will still show a minimum of 4 pounds even if I let it set for month. It will start with one pump of the gas days later.
Last edited by Aggressive Ted on Sun Aug 29, 2010 9:31 am, edited 1 time in total.
PostPosted: Sun Aug 29, 2010 9:19 am
The needle and seat are there to prevent excessive fuel from entering the bowl. Once the fuel level has fallen to below "full" (via evaporation or leak), the valve will be open.
Remember that the stock mechanical fuel pump, and any solenoid-type electric pump, contains two (2) check valves, one at the pump inlet and the other at the discharge. If the fuel pump is capable of developing pressure, its check valves are functional and fuel *cannot* drain back to the tank. If either check valve leaks, the pump will not develop its rated pressure.
Ken
PostPosted: Sun Aug 29, 2010 11:14 am
Pump is new, so I'll try Ted's advise. Any idea where I can get a good rebuikd kit which contains all these parts?
Thanks,
Antoon
PostPosted: Sun Aug 29, 2010 11:51 am
Look in the Engine FAQ, Carb section that SL6Dan put together. Part numbers for the Walker kits are listed. Also Joe's Carb Rebuild in Lynnwood has the individual parts for sale. Look under SL6 Network for address and number. Most NAPA Auto Parts carry them too.
PostPosted: Sun Aug 29, 2010 2:08 pm
Here's a solenoid style electric fuel pump that can be piped either series or parallel with the stock mechanical pump.
http://www.napaonline.com/Search/Detail ... 20+2020014
amazon.com has it for $47.95:
http://www.amazon.com/Bosch-69405-Elect ... B001C6254A
Advance Auto Parts has it for $62.49:
http://shop.advanceautoparts.com/1/2/66 ... 69405.html
It wil flow right around one fluid ounce per second, which will quickly fill the carburetor bowl. The easiest way to wire it is to connect it to the start circuit...when the engine cranks, it will run. If you run your engine at full power, I recommend piping in parallel. If you pipe in series, its probably best to pipe it between the mechanical pump and the carb. This arrangement doesn't affect the suction side of the mechanical pump, which is the most critical.
Ken
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 11 guests
