It is currently Mon Nov 16, 2026 5:02 am
PostPosted: Sat Apr 30, 2011 5:03 pm
Welded in bungs, Fuel rail drilled to o'ring size 2 stand offs taped with a socket head cap screw to hold it on.Will
http://i690.photobucket.com/albums/vv26 ... 040398.jpg
http://i690.photobucket.com/albums/vv26 ... 040399.jpg
http://i690.photobucket.com/albums/vv26 ... 020544.jpg
 Post subject: Injector bungs
PostPosted: Sat Apr 30, 2011 5:51 pm
Got a it of an angle on them,Did not get too excited its not a sequential setup its batch fire.i am running all holden commodore setup with the holden 808 ecu.ok at the moment
Fired it up the other day and after sorting an excessive oil pressure problem it runs ok at the moment.still some things to sort out
PostPosted: Thu May 05, 2011 3:48 pm
Here's another option for the fuel rail. It's more expensive than the Ross rail but I like that it already has the 6AN fittings on it that I wanted. They will also drill the bungs for you for another $50.
Moose
1966 Clark Cortez, Industrial /6
PostPosted: Thu May 05, 2011 3:54 pm
Thanks Moose! That isn't a bad deal at all.
