| 10" Drum Brake Conversion....Questions...! https://slantsix.org/forum/viewtopic.php?t=4886 |
Page 2 of 2 |
| Author: | Red [ Fri Jun 06, 2003 10:35 am ] |
Doc... R.e. your comment on my crude-but-effective T-bar tool: large striking surface was by design as on your back under the car makes for an awkward hammer swing (especially if a hand sledge is used as in PIC), so a large, solid target helps. That would be the main problem I'd have using a cable clamp: an old goat like me would would probably miss the durned thing completely with the hammer! I first tried using store-bought "L" brackets and u-bolts but they bent like pretzels w/o breaking the T-bars loose. So I fabbed this thing together out of much thicker stock with the gusset thrown in for overkill. Also cut and drilled new little cross pieces / clamping plates (what ARE those things called?) for the u-bolts out of thicker stock as the store-bought ones were too thin and maleable and bent as well. "What Miller Tool no longer provideth, the slanter must forgeth hisselfeth". ---Red |
| Author: | WaterBuffalo [ Mon Feb 09, 2004 10:49 am ] |
| Post subject: | Re: T-bar removal |
Quote: Here's what I use---
The pictures are gone, could you please post them again.Homemade torsion bar puller (disassembled): ![]() Homemade torsion bar puller (mounted snugly on breaker bar masquerading as a T-bar...rubber handle would be control arm end of T-bar...hammer head is addressing face of puller which is struck to break T-bar loose). Don't forget to take all weight off front suspension, remove T-bar C-clips and unload T-bar anchor bolts in lower control arms before swinging the hammer! ---Red Thanks Roman. |
| Author: | Guest [ Tue Feb 10, 2004 10:59 pm ] |
| Post subject: | Re: Thanks Matt... |
Quote: Thanks for the verification on the torsion bars...!! I will follow the proceedure..!! As for the upper ball joints, I am replacing the upper control arms with the 73-76 setup. I'm hoping I'll just have to un-bolt the current arms and not mess with un-hooking the existing upper ball joint. Well, since I have to release the torsion bars......I may just go ahead and replace the bars with new ones.....What do you think for size ? .87 or .89 ???
I don't stop here often, but in reading your post, you can't use the 73-76 upper control arm with small bolt 10" drums or with small bolt discs. The ball joint won't fit the spindle.
Thanks Matt by the way....how's your 66 Dart coming along..?? |
| Author: | DusterIdiot [ Tue Feb 10, 2004 11:39 pm ] |
| Post subject: | Right, but.... |
Quote: I don't stop here often, but in reading your post, you can't use the 73-76 upper control arm with small bolt 10" drums or with small bolt discs. The ball joint won't fit the spindle.
Matt ended up with a set of SBP 10" drums that slipped right onto his spindles, and the UCA's I believe are waiting for the day when the LBP disc setup get's installed (probably sometime after his slant pummels mine at the track, and about the same time he installs a better rear-end to match the LBP...)-D.Idiot |
| Page 2 of 2 | All times are UTC-07:00 |
