It is currently Sun Jun 14, 2026 8:48 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
 Post subject: good ideas...
PostPosted: Thu Apr 02, 2015 11:48 am
I like both the grease and the hylomar ideas. Grease permeates the paper and makes an effective water barrier, hylomar (and grease) lets you take it back apart without destroying the gaskets.
https://tinyurl.com/yynpj4v2
PostPosted: Thu Apr 02, 2015 3:02 pm
When i rebuilt my motor 2 years ago I used a Felpro gasket that had an adhesive on one side. You pulled off a cover like you would be pealing a sticker. Never had a leak yet. I attached it to the water pump first and then bolted it up to the block.
~Nic
 Post subject: adhesive...
PostPosted: Thu Apr 02, 2015 4:30 pm
Ah! So I was wrong, some do actually come with adhesive. Good to know.
brian
PostPosted: Thu Apr 02, 2015 6:45 pm
Also my thermostat gasket is the same way. Its a Felpro as well.
~Nic
 Post subject: Re: good ideas...
PostPosted: Fri Apr 03, 2015 9:52 am
or scraping
PostPosted: Sat Apr 11, 2015 9:26 am
here's what I used
I also put some on a cheap battery cable that had come loose.it stays stickie for ever, it's used on gas pump connectors.
slant six's RULE!
http://www.usajon.com
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
