| Presentation and ...question about carburetor https://slantsix.org/forum/viewtopic.php?t=59374 |
Page 2 of 2 |
| Author: | dodtorcito [ Wed May 04, 2016 2:41 am ] |
Hi. Yes ! I have checked for timing chain wear, and I haven't find any slopping out of the normal I have seen in others S6 of the time without problems. Also the first check I did was for the harmonic balancer sliping. I get an error of 2 degree retarded. I did new marks with paint between the internal and the external harmonic balancer rings and do the timming with it. This afternon I go to make some trials with severals springs I have made, and take note of the spring lever number and vac pot number Thank you in advance. |
| Author: | olafla [ Wed May 04, 2016 10:28 am ] |
Our member bigslant6fan has distributor spring kits, send him a pm. http://slantsix.org/forum/privmsg.php?mode=post&u=4774 Some links you may want to browse: http://slantsix.org/forum/viewtopic.php?p=330905 http://slantsix.org/forum/viewtopic.php?p=328519 http://slantsix.org/forum/viewtopic.php?p=319169 http://slantsix.org/forum/viewtopic.php?p=288143 Olaf |
| Author: | dodtorcito [ Wed May 04, 2016 2:23 pm ] |
Wow. Very usefull info in those posts, and the source for the springs. I will try to asimilate the maximum posible information. Very good and detailed work. Thank you. |
| Page 2 of 2 | All times are UTC-08:00 |
